1. Basic Predicate Calculus
1.1 An overview of the specification language Gallina
A formal development in Gallina consists in a sequence of declarations and definitions. You may also send Coq commands which are not really part of the formal development, but correspond to information requests, or service routine invocations. For instance, the command:
Coq < Quit.terminates the current session.
1.1.1 Declarations
A declaration associates a name with a specification. A name corresponds roughly to an identifier in a programming language, i.e. to a string of letters, digits, and a few ASCII symbols like underscore (_) and prime ('), starting with a letter.
We use case distinction, so that the names A and a are distinct.
Certain strings are reserved as key-words of Coq, and thus are forbidden
as user identifiers.A specification is a formal expression which classifies the notion which is being declared. There are basically three kinds of specifications: logical propositions, mathematical collections, and abstract types. They are classified by the three basic sorts of the system, called respectively
Prop, Set, and
Type, which are themselves atomic abstract types.Every valid expression e in Gallina is associated with a specification, itself a valid expression, called its type τ(E). We write e:τ(E) for the judgment that e is of type E. You may request Coq to return to you the type of a valid expression by using the command
Check:
Coq < Check O.
: nat
: nat
Thus we know that the identifier
O (the name `O', not to be
confused with the numeral `0' which is not a proper identifier!) is
known in the current context, and that its type is the specification
nat. This specification is itself classified as a mathematical
collection, as we may readily check:
Coq < Check nat.
nat
: Set
nat
: Set
The specification
Set is an abstract type, one of the basic
sorts of the Gallina language, whereas the notions nat and O are
notions which are defined in the arithmetic prelude,
automatically loaded when running the Coq system.We start by introducing a so-called section name. The role of sections is to structure the modelisation by limiting the scope of parameters, hypotheses and definitions. It will also give a convenient way to reset part of the development.
Coq < Section Declaration.
With what we already know, we may now enter in the system a declaration,
corresponding to the informal mathematics let n be a natural
number.
Coq < Variable n : nat.
n is assumed
n is assumed
If we want to translate a more precise statement, such as let n be a positive natural number, we have to add another declaration, which will declare explicitly the hypothesis
Pos_n, with specification the proper logical
proposition:
Coq < Hypothesis Pos_n : (gt n 0).
Pos_n is assumed
Pos_n is assumed
Indeed we may check that the relation
gt is known with the right type
in the current context:
Coq < Check gt.
gt
: nat -> nat -> Prop
gt
which tells us that
gt is a function expecting two arguments of
type nat in order to build a logical proposition.
What happens here is similar to what we are used to in a functional
programming language: we may compose the (specification) type nat
with the (abstract) type Prop of logical propositions through the
arrow function constructor, in order to get a functional type
nat->Prop:
Coq < Check (nat -> Prop).
nat -> Prop
: Type
which may be composed again with nat -> Prop
: Type
nat in order to obtain the
type nat->nat->Prop of binary relations over natural numbers.
Actually nat->nat->Prop is an abbreviation for
nat->(nat->Prop). Functional notions may be composed in the usual way. An expression f of type A→ B may be applied to an expression e of type A in order to form the expression (f e) of type B. Here we get that the expression
(gt n) is well-formed of type nat->Prop,
and thus that the expression (gt n O), which abbreviates
((gt n) O), is a well-formed proposition.
Coq < Check gt n O.
n > 0
: Prop
n > 0
: Prop
1.1.2 Definitions
The initial prelude contains a few arithmetic definitions:nat is defined as a mathematical collection (type Set), constants
O, S, plus, are defined as objects of types
respectively nat, nat->nat, and nat->nat->nat.
You may introduce new definitions, which link a name to a well-typed value.
For instance, we may introduce the constant one as being defined
to be equal to the successor of zero:
Coq < Definition one := (S O).
one is defined
We may optionally indicate the required type:
one is defined
Coq < Definition two : nat := S one.
two is defined
two is defined
Actually Coq allows several possible syntaxes:
Coq < Definition three : nat := S two.
three is defined
three is defined
Here is a way to define the doubling function, which expects an argument
m of type nat in order to build its result as
(plus m m):
Coq < Definition double (m:nat) := plus m m.
double is defined
This definition introduces the constant double defined as the
expression fun m:nat => plus m m.
The abstraction introduced by fun is explained as follows. The expression
double is defined
fun x:A => e is well formed of type A->B in a context
whenever the expression e is well-formed of type B in
the given context to which we add the declaration that x
is of type A. Here x is a bound, or dummy variable in
the expression fun x:A => e. For instance we could as well have
defined double as fun n:nat => (plus n n).Bound (local) variables and free (global) variables may be mixed. For instance, we may define the function which adds the constant
n
to its argument as
Coq < Definition add_n (m:nat) := plus m n.
add_n is defined
However, note that here we may not rename the formal argument m into n
without capturing the free occurrence of n, and thus changing the meaning
of the defined notion.add_n is defined
Binding operations are well known for instance in logic, where they are called quantifiers. Thus we may universally quantify a proposition such as m>0 in order to get a universal proposition ∀ m⋅ m>0. Indeed this operator is available in Coq, with the following syntax:
forall m:nat, gt m O. Similarly to the
case of the functional abstraction binding, we are obliged to declare
explicitly the type of the quantified variable. We check:
Coq < Check (forall m:nat, gt m 0).
forall m : nat, m > 0
: Prop
We may clean-up the development by removing the contents of the
current section:
: Prop
Coq < Reset Declaration.
1.2 Introduction to the proof engine: Minimal Logic
In the following, we are going to consider various propositions, built from atomic propositions A, B, C. This may be done easily, by introducing these atoms as global variables declared of type
Prop.
It is easy to declare several names with the same specification:
Coq < Section Minimal_Logic.
Coq < Variables A B C : Prop.
A is assumed
B is assumed
C is assumed
A is assumed
B is assumed
C is assumed
We shall consider simple implications, such as A→ B, read as “A implies B”. Remark that we overload the arrow symbol, which has been used above as the functionality type constructor, and which may be used as well as propositional connective:
Coq < Check (A -> B).
A -> B
: Prop
A -> B
: Prop
Let us now embark on a simple proof. We want to prove the easy tautology ((A→ (B→ C))→ (A→ B)→ (A→ C). We enter the proof engine by the command
Goal, followed by the conjecture we want to verify:
Coq < Goal (A -> B -> C) -> (A -> B) -> A -> C.
1 subgoal
A : Prop
B : Prop
C : Prop
1 subgoal
A : Prop
B : Prop
C : Prop
The system displays the current goal below a double line, local hypotheses (there are none initially) being displayed above the line. We call the combination of local hypotheses with a goal a judgment. We are now in an inner loop of the system, in proof mode. New commands are available in this mode, such as tactics, which are proof combining primitives. A tactic operates on the current goal by attempting to construct a proof of the corresponding judgment, possibly from proofs of some hypothetical judgments, which are then added to the current list of conjectured judgments. For instance, the
intro tactic is applicable to any judgment
whose goal is an implication, by moving the proposition to the left
of the application to the list of local hypotheses:
Coq < intro H.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
(A -> B) -> A -> C
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
(A -> B) -> A -> C
Several introductions may be done in one step:
Coq < intros H' HA.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H' : A -> B
HA : A
C
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H' : A -> B
HA : A
C
We notice that C, the current goal, may be obtained from hypothesis
H, provided the truth of A and B are established.
The tactic apply implements this piece of reasoning:
Coq < apply H.
2 subgoals
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H' : A -> B
HA : A
A
subgoal 2 is:
B
2 subgoals
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H' : A -> B
HA : A
A
subgoal 2 is:
B
We are now in the situation where we have two judgments as conjectures that remain to be proved. Only the first is listed in full, for the others the system displays only the corresponding subgoal, without its local hypotheses list. Remark that
apply has kept the local
hypotheses of its father judgment, which are still available for
the judgments it generated.In order to solve the current goal, we just have to notice that it is exactly available as hypothesis HA:
Coq < exact HA.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H' : A -> B
HA : A
B
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H' : A -> B
HA : A
B
Now H' applies:
Coq < apply H'.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H' : A -> B
HA : A
A
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H' : A -> B
HA : A
A
And we may now conclude the proof as before, with
exact HA.
Actually, we may not bother with the name HA, and just state that
the current goal is solvable from the current local assumptions:
Coq < assumption.
Proof completed.
Proof completed.
The proof is now finished. We may either discard it, by using the command
Abort which returns to the standard Coq toplevel loop
without further ado, or else save it as a lemma in the current context,
under name say trivial_lemma:
Coq < Save trivial_lemma.
intro H.
intros H' HA.
apply H.
exact HA.
apply H'.
assumption.
trivial_lemma is defined
intro H.
intros H' HA.
apply H.
exact HA.
apply H'.
assumption.
As a comment, the system shows the proof script listing all tactic commands used in the proof.
Let us redo the same proof with a few variations. First of all we may name the initial goal as a conjectured lemma:
Coq < Lemma distr_impl : (A -> B -> C) -> (A -> B) -> A -> C.
1 subgoal
A : Prop
B : Prop
C : Prop
1 subgoal
A : Prop
B : Prop
C : Prop
Next, we may omit the names of local assumptions created by the introduction tactics, they can be automatically created by the proof engine as new non-clashing names.
Coq < intros.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H0 : A -> B
H1 : A
C
1 subgoal
A : Prop
B : Prop
C : Prop
H : A -> B -> C
H0 : A -> B
H1 : A
C
The
intros tactic, with no arguments, effects as many individual
applications of intro as is legal.Then, we may compose several tactics together in sequence, or in parallel, through tacticals, that is tactic combinators. The main constructions are the following:
- T1 ; T2 (read T1 then T2) applies tactic T1 to the current goal, and then tactic T2 to all the subgoals generated by T1.
- T; [T1 | T2 | ... | Tn] applies tactic T to the current goal, and then tactic T1 to the first newly generated subgoal, ..., Tn to the nth.
distr_impl with one composite tactic:
Coq < apply H; [ assumption | apply H0; assumption ].
Proof completed.
Proof completed.
Let us now save lemma
distr_impl:
Coq < Save.
intros.
distr_impl is defined
intros.
Here
Save needs no argument, since we gave the name distr_impl
in advance;
it is however possible to override the given name by giving a different
argument to command Save.Actually, such an easy combination of tactics
intro, apply
and assumption may be found completely automatically by an automatic
tactic, called auto, without user guidance:
Coq < Lemma distr_imp : (A -> B -> C) -> (A -> B) -> A -> C.
1 subgoal
A : Prop
B : Prop
C : Prop
Coq < auto.
Proof completed.
1 subgoal
A : Prop
B : Prop
C : Prop
Coq < auto.
Proof completed.
This time, we do not save the proof, we just discard it with the
Abort
command:
Coq < Abort.
Current goal aborted
At any point during a proof, we may use
Abort to exit the proof mode
and go back to Coq's main loop. We may also use Restart to restart
from scratch the proof of the same lemma. We may also use Undo to
backtrack one step, and more generally Undo n to
backtrack n steps.We end this section by showing a useful command,
Inspect n.,
which inspects the global Coq environment, showing the last n declared
notions:
Coq < Inspect 3.
*** [C : Prop]
trivial_lemma : (A -> B -> C) -> (A -> B) -> A -> C
*** [C : Prop]
The declarations, whether global parameters or axioms, are shown preceded by
***; definitions and lemmas are stated with their specification, but
their value (or proof-term) is omitted.1.3 Propositional Calculus
1.3.1 Conjunction
We have seen howintro and apply tactics could be combined
in order to prove implicational statements. More generally, Coq favors a style
of reasoning, called Natural Deduction, which decomposes reasoning into
so called introduction rules, which tell how to prove a goal whose main
operator is a given propositional connective, and elimination rules,
which tell how to use an hypothesis whose main operator is the propositional
connective. Let us show how to use these ideas for the propositional connectives
/\ and \/.
Coq < Lemma and_commutative : A /\ B -> B /\ A.
1 subgoal
A : Prop
B : Prop
C : Prop
A /\ B -> B /\ A
Coq < intro.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A /\ B
B /\ A
1 subgoal
A : Prop
B : Prop
C : Prop
A /\ B -> B /\ A
Coq < intro.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A /\ B
B /\ A
We make use of the conjunctive hypothesis
H with the elim tactic,
which breaks it into its components:
Coq < elim H.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A /\ B
A -> B -> B /\ A
1 subgoal
A : Prop
B : Prop
C : Prop
H : A /\ B
A -> B -> B /\ A
We now use the conjunction introduction tactic
split, which splits the
conjunctive goal into the two subgoals:
Coq < split.
2 subgoals
A : Prop
B : Prop
C : Prop
H : A /\ B
H0 : A
H1 : B
B
subgoal 2 is:
A
2 subgoals
A : Prop
B : Prop
C : Prop
H : A /\ B
H0 : A
H1 : B
B
subgoal 2 is:
A
and the proof is now trivial. Indeed, the whole proof is obtainable as follows:
Coq < Restart.
1 subgoal
A : Prop
B : Prop
C : Prop
A /\ B -> B /\ A
Coq < intro H; elim H; auto.
Proof completed.
Coq < Qed.
and_commutative is defined
1 subgoal
A : Prop
B : Prop
C : Prop
A /\ B -> B /\ A
Proof completed.
Coq < Qed.
The tactic
auto succeeded here because it knows as a hint the
conjunction introduction operator conj
Coq < Check conj.
conj
: forall A B : Prop, A -> B -> A /\ B
conj
Actually, the tactic
Split is just an abbreviation for apply conj.What we have just seen is that the
auto tactic is more powerful than
just a simple application of local hypotheses; it tries to apply as well
lemmas which have been specified as hints. A
Hint Resolve command registers a
lemma as a hint to be used from now on by the auto tactic, whose power
may thus be incrementally augmented.1.3.2 Disjunction
In a similar fashion, let us consider disjunction:
Coq < Lemma or_commutative : A \/ B -> B \/ A.
1 subgoal
A : Prop
B : Prop
C : Prop
A \/ B -> B \/ A
Coq < intro H; elim H.
2 subgoals
A : Prop
B : Prop
C : Prop
H : A \/ B
A -> B \/ A
subgoal 2 is:
B -> B \/ A
1 subgoal
A : Prop
B : Prop
C : Prop
A \/ B -> B \/ A
2 subgoals
A : Prop
B : Prop
C : Prop
H : A \/ B
A -> B \/ A
subgoal 2 is:
B -> B \/ A
Let us prove the first subgoal in detail. We use
intro in order to
be left to prove B\/A from A:
Coq < intro HA.
2 subgoals
A : Prop
B : Prop
C : Prop
H : A \/ B
HA : A
B \/ A
subgoal 2 is:
B -> B \/ A
2 subgoals
A : Prop
B : Prop
C : Prop
H : A \/ B
HA : A
B \/ A
subgoal 2 is:
B -> B \/ A
Here the hypothesis
H is not needed anymore. We could choose to
actually erase it with the tactic clear; in this simple proof it
does not really matter, but in bigger proof developments it is useful to
clear away unnecessary hypotheses which may clutter your screen.
Coq < clear H.
2 subgoals
A : Prop
B : Prop
C : Prop
HA : A
B \/ A
subgoal 2 is:
B -> B \/ A
2 subgoals
A : Prop
B : Prop
C : Prop
HA : A
B \/ A
subgoal 2 is:
B -> B \/ A
The disjunction connective has two introduction rules, since
P\/Q
may be obtained from P or from Q; the two corresponding
proof constructors are called respectively or_introl and
or_intror; they are applied to the current goal by tactics
left and right respectively. For instance:
Coq < right.
2 subgoals
A : Prop
B : Prop
C : Prop
HA : A
A
subgoal 2 is:
B -> B \/ A
Coq < trivial.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A \/ B
B -> B \/ A
The tactic 2 subgoals
A : Prop
B : Prop
C : Prop
HA : A
A
subgoal 2 is:
B -> B \/ A
Coq < trivial.
1 subgoal
A : Prop
B : Prop
C : Prop
H : A \/ B
B -> B \/ A
trivial works like auto with the hints
database, but it only tries those tactics that can solve the goal in one
step. As before, all these tedious elementary steps may be performed automatically, as shown for the second symmetric case:
Coq < auto.
Proof completed.
Proof completed.
However,
auto alone does not succeed in proving the full lemma, because
it does not try any elimination step.
It is a bit disappointing that auto is not able to prove automatically
such a simple tautology. The reason is that we want to keep
auto efficient, so that it is always effective to use. 1.3.3 Tauto
A complete tactic for propositional tautologies is indeed available in Coq as thetauto tactic.
Coq < Restart.
1 subgoal
A : Prop
B : Prop
C : Prop
A \/ B -> B \/ A
Coq < tauto.
Proof completed.
Coq < Qed.
tauto.
or_commutative is defined
1 subgoal
A : Prop
B : Prop
C : Prop
A \/ B -> B \/ A
Coq < tauto.
Proof completed.
Coq < Qed.
tauto.
It is possible to inspect the actual proof tree constructed by
tauto,
using a standard command of the system, which prints the value of any notion
currently defined in the context:
Coq < Print or_commutative.
or_commutative =
fun H : A \/ B =>
or_ind (fun H0 : A => or_intror B H0) (fun H0 : B => or_introl A H0) H
: A \/ B -> B \/ A
or_commutative =
fun H : A \/ B =>
: A \/ B -> B \/ A
It is not easy to understand the notation for proof terms without a few explanations. The fun prefix, such as
fun H:A\/B =>,
corresponds
to intro H, whereas a subterm such as
(or_intror B H0)
corresponds to the sequence apply or_intror; exact H0.
The generic combinator or_intror needs to be instantiated by
the two properties B and A. Because A can be
deduced from the type of H0, only B is printed.
The two instantiations are effected automatically by the tactic
apply when pattern-matching a goal. The specialist will of course
recognize our proof term as a λ-term, used as notation for the
natural deduction proof term through the Curry-Howard isomorphism. The
naive user of Coq may safely ignore these formal details.Let us exercise the
tauto tactic on a more complex example:
Coq < Lemma distr_and : A -> B /\ C -> (A -> B) /\ (A -> C).
1 subgoal
A : Prop
B : Prop
C : Prop
Coq < tauto.
Proof completed.
Coq < Qed.
tauto.
distr_and is defined
1 subgoal
A : Prop
B : Prop
C : Prop
Coq < tauto.
Proof completed.
Coq < Qed.
tauto.
1.3.4 classical reasoning
tauto always comes back with an answer. Here is an example where it
fails:
Coq < Lemma Peirce : ((A -> B) -> A) -> A.
1 subgoal
A : Prop
B : Prop
C : Prop
Coq < try tauto.
1 subgoal
A : Prop
B : Prop
C : Prop
1 subgoal
A : Prop
B : Prop
C : Prop
Coq < try tauto.
1 subgoal
A : Prop
B : Prop
C : Prop
Note the use of the
Try tactical, which does nothing if its tactic
argument fails.This may come as a surprise to someone familiar with classical reasoning. Peirce's lemma is true in Boolean logic, i.e. it evaluates to
true for
every truth-assignment to A and B. Indeed the double negation
of Peirce's law may be proved in Coq using tauto:
Coq < Abort.
Coq < Lemma NNPeirce : ~ ~ (((A -> B) -> A) -> A).
1 subgoal
A : Prop
B : Prop
C : Prop
Coq < tauto.
Proof completed.
Coq < Qed.
tauto.
NNPeirce is defined
1 subgoal
A : Prop
B : Prop
C : Prop
Coq < tauto.
Proof completed.
Coq < Qed.
tauto.
NNPeirce is defined
In classical logic, the double negation of a proposition is equivalent to this proposition, but in the constructive logic of Coq this is not so. If you want to use classical logic in Coq, you have to import explicitly the
Classical module, which will declare the axiom classic
of excluded middle, and classical tautologies such as de Morgan's laws.
The Require command is used to import a module from Coq's library:
Coq < Require Import Classical.
Coq < Check NNPP.
NNPP
: forall p : Prop, ~ ~ p -> p
Coq < Check NNPP.
NNPP
and it is now easy (although admittedly not the most direct way) to prove a classical law such as Peirce's:
1 subgoal
A : Prop
B : Prop
C : Prop
Coq < apply NNPP; tauto.
Proof completed.
Coq < Qed.
apply NNPP; tauto.
Peirce is defined
1 subgoal
A : Prop
B : Prop
C : Prop
Proof completed.
Coq < Qed.
apply NNPP; tauto.
Peirce is defined
Here is one more example of propositional reasoning, in the shape of a Scottish puzzle. A private club has the following rules:
- Every non-scottish member wears red socks
- Every member wears a kilt or doesn't wear red socks
- The married members don't go out on Sunday
- A member goes out on Sunday if and only if he is Scottish
- Every member who wears a kilt is Scottish and married
- Every scottish member wears a kilt
Coq < Section club.
Coq < Variables Scottish RedSocks WearKilt Married GoOutSunday : Prop.
Scottish is assumed
RedSocks is assumed
WearKilt is assumed
Married is assumed
GoOutSunday is assumed
Coq < Hypothesis rule1 : ~ Scottish -> RedSocks.
rule1 is assumed
Coq < Hypothesis rule2 : WearKilt \/ ~ RedSocks.
rule2 is assumed
Coq < Hypothesis rule3 : Married -> ~ GoOutSunday.
rule3 is assumed
Coq < Hypothesis rule4 : GoOutSunday <-> Scottish.
rule4 is assumed
Coq < Hypothesis rule5 : WearKilt -> Scottish /\ Married.
rule5 is assumed
Coq < Hypothesis rule6 : Scottish -> WearKilt.
rule6 is assumed
Coq < Lemma NoMember : False.
1 subgoal
A : Prop
B : Prop
C : Prop
Scottish : Prop
RedSocks : Prop
WearKilt : Prop
Married : Prop
GoOutSunday : Prop
False
Coq < tauto.
Proof completed.
Coq < Qed.
tauto.
NoMember is defined
At that point Coq < Variables Scottish RedSocks WearKilt Married GoOutSunday : Prop.
Scottish is assumed
RedSocks is assumed
WearKilt is assumed
Married is assumed
rule1 is assumed
rule2 is assumed
rule3 is assumed
rule4 is assumed
rule5 is assumed
rule6 is assumed
1 subgoal
A : Prop
B : Prop
C : Prop
Scottish : Prop
RedSocks : Prop
WearKilt : Prop
Married : Prop
GoOutSunday : Prop
False
Coq < tauto.
Proof completed.
Coq < Qed.
tauto.
NoMember is defined
NoMember is a proof of the absurdity depending on
hypotheses.
We may end the section, in that case, the variables and hypotheses
will be discharged, and the type of NoMember will be
generalised.
Coq < End club.
Coq < Check NoMember.
NoMember
: forall Scottish RedSocks WearKilt Married GoOutSunday : Prop,
(~ Scottish -> RedSocks) ->
WearKilt \/ ~ RedSocks ->
(Married -> ~ GoOutSunday) ->
(GoOutSunday <-> Scottish) ->
(WearKilt -> Scottish /\ Married) ->
(Scottish -> WearKilt) -> False
NoMember
1.4 predicate Calculus
Let us now move into predicate logic, and first of all into first-order predicate calculus. The essence of predicate calculus is that to try to prove theorems in the most abstract possible way, without using the definitions of the mathematical notions, but by formal manipulations of uninterpreted function and predicate symbols.
1.4.1 Sections and signatures
Usually one works in some domain of discourse, over which range the individual variables and function symbols. In Coq we speak in a language with a rich variety of types, so me may mix several domains of discourse, in our multi-sorted language. For the moment, we just do a few exercises, over a domain of discourseD axiomatised as a Set, and we consider two
predicate symbols P and R over D, of arities
respectively 1 and 2. Such abstract entities may be entered in the context
as global variables. But we must be careful about the pollution of our
global environment by such declarations. For instance, we have already
polluted our Coq session by declaring the variables
n, Pos_n, A, B, and C. If we want to revert to the clean state of
our initial session, we may use the Coq Reset command, which returns
to the state just prior the given global notion as we did before to
remove a section, or we may return to the initial state using :
Coq < Reset Initial.
We shall now declare a new
Section, which will allow us to define
notions local to a well-delimited scope. We start by assuming a domain of
discourse D, and a binary relation R over D:
Coq < Section predicate_calculus.
Coq < Variable D : Set.
D is assumed
Coq < Variable R : D -> D -> Prop.
R is assumed
D is assumed
R is assumed
As a simple example of predicate calculus reasoning, let us assume that relation
R is symmetric and transitive, and let us show that
R is reflexive in any point x which has an R successor.
Since we do not want to make the assumptions about R global axioms of
a theory, but rather local hypotheses to a theorem, we open a specific
section to this effect.
Coq < Section R_sym_trans.
Coq < Hypothesis R_symmetric : forall x y:D, R x y -> R y x.
R_symmetric is assumed
Coq < Hypothesis R_transitive : forall x y z:D, R x y -> R y z -> R x z.
R_transitive is assumed
Remark the syntax
forall x:D, which stands for universal quantification
∀ x : D.1.4.2 Existential quantification
We now state our lemma, and enter proof mode.
Coq < Lemma refl_if : forall x:D, (exists y, R x y) -> R x x.
1 subgoal
D : Set
R : D -> D -> Prop
R_symmetric : forall x y : D, R x y -> R y x
R_transitive : forall x y z : D, R x y -> R y z -> R x z
forall x : D, (exists y : D, R x y) -> R x x
1 subgoal
D : Set
R : D -> D -> Prop
Remark that the hypotheses which are local to the currently opened sections are listed as local hypotheses to the current goals. The rationale is that these hypotheses are going to be discharged, as we shall see, when we shall close the corresponding sections.
Note the functional syntax for existential quantification. The existential quantifier is built from the operator
ex, which expects a
predicate as argument:
Coq < Check ex.
ex
: forall A : Type, (A -> Prop) -> Prop
and the notation ex
(exists x:D, P x) is just concrete syntax for
(ex D (fun x:D => P x)).
Existential quantification is handled in Coq in a similar
fashion to the connectives /\ and \/ : it is introduced by
the proof combinator ex_intro, which is invoked by the specific
tactic Exists, and its elimination provides a witness a:D to
P, together with an assumption h:(P a) that indeed a
verifies P. Let us see how this works on this simple example.
Coq < intros x x_Rlinked.
1 subgoal
D : Set
R : D -> D -> Prop
x : D
x_Rlinked : exists y : D, R x y
R x x
1 subgoal
D : Set
R : D -> D -> Prop
x : D
R x x
Remark that
intros treats universal quantification in the same way
as the premises of implications. Renaming of bound variables occurs
when it is needed; for instance, had we started with intro y,
we would have obtained the goal:
Coq < intro y.
1 subgoal
D : Set
R : D -> D -> Prop
y : D
(exists y0 : D, R y y0) -> R y y
1 subgoal
D : Set
R : D -> D -> Prop
y : D
Let us now use the existential hypothesis
x_Rlinked to
exhibit an R-successor y of x. This is done in two steps, first with
elim, then with intros
Coq < elim x_Rlinked.
1 subgoal
D : Set
R : D -> D -> Prop
x : D
forall x0 : D, R x x0 -> R x x
Coq < intros y Rxy.
1 subgoal
D : Set
R : D -> D -> Prop
x : D
y : D
Rxy : R x y
R x x
1 subgoal
D : Set
R : D -> D -> Prop
x : D
Coq < intros y Rxy.
1 subgoal
D : Set
R : D -> D -> Prop
x : D
y : D
Rxy : R x y
R x x
Now we want to use
R_transitive. The apply tactic will know
how to match x with x, and z with x, but needs
help on how to instantiate y, which appear in the hypotheses of
R_transitive, but not in its conclusion. We give the proper hint
to apply in a with clause, as follows:
Coq < apply R_transitive with y.
2 subgoals
D : Set
R : D -> D -> Prop
x : D
y : D
Rxy : R x y
R x y
subgoal 2 is:
R y x
2 subgoals
D : Set
R : D -> D -> Prop
x : D
y : D
Rxy : R x y
R x y
subgoal 2 is:
R y x
The rest of the proof is routine:
Coq < assumption.
1 subgoal
D : Set
R : D -> D -> Prop
x : D
y : D
Rxy : R x y
R y x
Coq < apply R_symmetric; assumption.
Proof completed.
Coq < Qed.
1 subgoal
D : Set
R : D -> D -> Prop
x : D
y : D
Rxy : R x y
R y x
Proof completed.
Coq < Qed.
Let us now close the current section.
Coq < End R_sym_trans.
Here Coq's printout is a warning that all local hypotheses have been discharged in the statement of
refl_if, which now becomes a general
theorem in the first-order language declared in section
predicate_calculus. In this particular example, the use of section
R_sym_trans has not been really significant, since we could have
instead stated theorem refl_if in its general form, and done
basically the same proof, obtaining R_symmetric and
R_transitive as local hypotheses by initial intros rather
than as global hypotheses in the context. But if we had pursued the
theory by proving more theorems about relation R,
we would have obtained all general statements at the closing of the section,
with minimal dependencies on the hypotheses of symmetry and transitivity.1.4.3 Paradoxes of classical predicate calculus
Let us illustrate this feature by pursuing ourpredicate_calculus
section with an enrichment of our language: we declare a unary predicate
P and a constant d:
Coq < Variable P : D -> Prop.
P is assumed
Coq < Variable d : D.
d is assumed
P is assumed
d is assumed
We shall now prove a well-known fact from first-order logic: a universal predicate is non-empty, or in other terms existential quantification follows from universal quantification.
Coq < Lemma weird : (forall x:D, P x) -> exists a, P a.
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
(forall x : D, P x) -> exists a : D, P a
Coq < intro UnivP.
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
UnivP : forall x : D, P x
exists a : D, P a
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
Coq < intro UnivP.
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
exists a : D, P a
First of all, notice the pair of parentheses around
forall x:D, P x in
the statement of lemma weird.
If we had omitted them, Coq's parser would have interpreted the
statement as a truly trivial fact, since we would
postulate an x verifying (P x). Here the situation is indeed
more problematic. If we have some element in Set D, we may
apply UnivP to it and conclude, otherwise we are stuck. Indeed
such an element d exists, but this is just by virtue of our
new signature. This points out a subtle difference between standard
predicate calculus and Coq. In standard first-order logic,
the equivalent of lemma weird always holds,
because such a rule is wired in the inference rules for quantifiers, the
semantic justification being that the interpretation domain is assumed to
be non-empty. Whereas in Coq, where types are not assumed to be
systematically inhabited, lemma weird only holds in signatures
which allow the explicit construction of an element in the domain of
the predicate. Let us conclude the proof, in order to show the use of the
Exists
tactic:
Coq < exists d; trivial.
Proof completed.
Coq < Qed.
intro UnivP.
exists d; trivial.
weird is defined
Proof completed.
Coq < Qed.
intro UnivP.
exists d; trivial.
weird is defined
Another fact which illustrates the sometimes disconcerting rules of classical predicate calculus is Smullyan's drinkers' paradox: “In any non-empty bar, there is a person such that if she drinks, then everyone drinks”. We modelize the bar by Set
D, drinking by predicate P.
We shall need classical reasoning. Instead of loading the classical
module as we did above, we just state the law of excluded middle as a
local hypothesis schema at this point:
Coq < Hypothesis EM : forall A:Prop, A \/ ~ A.
EM is assumed
Coq < Lemma drinker : exists x:D, P x -> forall x:D, P x.
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
EM : forall A : Prop, A \/ ~ A
exists x : D, P x -> forall x0 : D, P x0
The proof goes by cases on whether or not
there is someone who does not drink. Such reasoning by cases proceeds
by invoking the excluded middle principle, via EM is assumed
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
elim of the
proper instance of EM:
Coq < elim (EM (exists x, ~ P x)).
2 subgoals
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
(exists x : D, ~ P x) -> exists x : D, P x -> forall x0 : D, P x0
subgoal 2 is:
~ (exists x : D, ~ P x) -> exists x : D, P x -> forall x0 : D, P x0
2 subgoals
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
subgoal 2 is:
We first look at the first case. Let Tom be the non-drinker:
Coq < intro Non_drinker; elim Non_drinker; intros Tom Tom_does_not_drink.
2 subgoals
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
Non_drinker : exists x : D, ~ P x
Tom : D
Tom_does_not_drink : ~ P Tom
subgoal 2 is:
2 subgoals
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
Tom : D
subgoal 2 is:
We conclude in that case by considering Tom, since his drinking leads to a contradiction:
Coq < exists Tom; intro Tom_drinks.
2 subgoals
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
Tom : D
Tom_drinks : P Tom
forall x : D, P x
subgoal 2 is:
2 subgoals
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
Tom : D
Tom_drinks : P Tom
forall x : D, P x
subgoal 2 is:
There are several ways in which we may eliminate a contradictory case; a simple one is to use the
absurd tactic as follows:
Coq < absurd (P Tom); trivial.
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
We now proceed with the second case, in which actually any person will do; such a John Doe is given by the non-emptiness witness
d:
Coq < intro No_nondrinker; exists d; intro d_drinks.
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
No_nondrinker : ~ (exists x : D, ~ P x)
d_drinks : P d
forall x : D, P x
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
d_drinks : P d
forall x : D, P x
Now we consider any Dick in the bar, and reason by cases according to its drinking or not:
Coq < intro Dick; elim (EM (P Dick)); trivial.
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
d_drinks : P d
Dick : D
~ P Dick -> P Dick
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
d_drinks : P d
Dick : D
~ P Dick -> P Dick
The only non-trivial case is again treated by contradiction:
Coq < intro Dick_does_not_drink; absurd (exists x, ~ P x); trivial.
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
d_drinks : P d
Dick : D
Dick_does_not_drink : ~ P Dick
exists x : D, ~ P x
Coq < exists Dick; trivial.
Proof completed.
Coq < Qed.
elim (EM (exists x : _, ~ P x)).
intro Dick_does_not_drink; absurd (exists x : _, ~ P x); trivial.
drinker is defined
1 subgoal
D : Set
R : D -> D -> Prop
P : D -> Prop
d : D
d_drinks : P d
Dick : D
exists x : D, ~ P x
Proof completed.
Coq < Qed.
drinker is defined
Now, let us close the main section and look at the complete statements we proved:
Coq < End predicate_calculus.
Coq < Check refl_if.
refl_if
: forall (D : Set) (R : D -> D -> Prop),
(forall x y : D, R x y -> R y x) ->
(forall x y z : D, R x y -> R y z -> R x z) ->
Coq < Check weird.
weird
: forall (D : Set) (P : D -> Prop),
D -> (forall x : D, P x) -> exists a : D, P a
Coq < Check drinker.
drinker
D ->
(forall A : Prop, A \/ ~ A) ->
refl_if
Coq < Check weird.
weird
drinker
D ->
Remark how the three theorems are completely generic in the most general fashion; the domain
D is discharged in all of them, R is discharged in
refl_if only, P is discharged only in weird and
drinker, along with the hypothesis that D is inhabited.
Finally, the excluded middle hypothesis is discharged only in
drinker.Note that the name
d has vanished as well from
the statements of weird and drinker,
since Coq's pretty-printer replaces
systematically a quantification such as forall d:D, E, where d
does not occur in E, by the functional notation D->E.
Similarly the name EM does not appear in drinker. Actually, universal quantification, implication, as well as function formation, are all special cases of one general construct of type theory called dependent product. This is the mathematical construction corresponding to an indexed family of functions. A function f∈ Π x:D⋅ Cx maps an element x of its domain D to its (indexed) codomain Cx. Thus a proof of ∀ x:D⋅ Px is a function mapping an element x of D to a proof of proposition Px.
1.4.4 Flexible use of local assumptions
Very often during the course of a proof we want to retrieve a local assumption and reintroduce it explicitly in the goal, for instance in order to get a more general induction hypothesis. The tacticgeneralize is what is needed here:
Coq < Section predicate_Calculus.
Coq < Variables P Q : nat -> Prop.
P is assumed
Q is assumed
Coq < Variable R : nat -> nat -> Prop.
R is assumed
Coq < Lemma PQR :
Coq < forall x y:nat, (R x x -> P x -> Q x) -> P x -> R x y -> Q x.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
forall x y : nat, (R x x -> P x -> Q x) -> P x -> R x y -> Q x
Coq < intros.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
x : nat
y : nat
H : R x x -> P x -> Q x
H0 : P x
H1 : R x y
Q x
Coq < generalize H0.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
x : nat
y : nat
H0 : P x
H1 : R x y
P x -> Q x
P is assumed
Q is assumed
R is assumed
Coq < Lemma PQR :
1 subgoal
P : nat -> Prop
Q : nat -> Prop
Coq < intros.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
x : nat
y : nat
H0 : P x
H1 : R x y
Q x
1 subgoal
P : nat -> Prop
Q : nat -> Prop
x : nat
y : nat
H0 : P x
H1 : R x y
P x -> Q x
Sometimes it may be convenient to use a lemma, although we do not have a direct way to appeal to such an already proven fact. The tactic
cut
permits to use the lemma at this point, keeping the corresponding proof
obligation as a new subgoal:
Coq < cut (R x x); trivial.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
x : nat
y : nat
H0 : P x
H1 : R x y
R x x
We clean the goal by doing an 1 subgoal
P : nat -> Prop
Q : nat -> Prop
x : nat
y : nat
H0 : P x
H1 : R x y
R x x
Abort command.
Coq < Abort.
1.4.5 Equality
The basic equality provided in Coq is Leibniz equality, noted infix likex=y, when x and y are two expressions of
type the same Set. The replacement of x by y in any
term is effected by a variety of tactics, such as rewrite
and replace. Let us give a few examples of equality replacement. Let us assume that some arithmetic function
f is null in zero:
Coq < Variable f : nat -> nat.
f is assumed
Coq < Hypothesis foo : f 0 = 0.
foo is assumed
f is assumed
foo is assumed
We want to prove the following conditional equality:
Coq < Lemma L1 : forall k:nat, k = 0 -> f k = k.
As usual, we first get rid of local assumptions with
intro:
Coq < intros k E.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
k : nat
E : k = 0
f k = k
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
k : nat
E : k = 0
f k = k
Let us now use equation
E as a left-to-right rewriting:
Coq < rewrite E.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
k : nat
E : k = 0
f 0 = 0
This replaced both occurrences of 1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
k : nat
E : k = 0
f 0 = 0
k by O. Now
apply foo will finish the proof:
Coq < apply foo.
Proof completed.
Coq < Qed.
intros k E.
rewrite E in |- *.
apply foo.
L1 is defined
Proof completed.
Coq < Qed.
intros k E.
rewrite E in |- *.
apply foo.
L1 is defined
When one wants to rewrite an equality in a right to left fashion, we should use
rewrite <- E rather than rewrite E or the equivalent
rewrite -> E.
Let us now illustrate the tactic replace.
Coq < Hypothesis f10 : f 1 = f 0.
f10 is assumed
Coq < Lemma L2 : f (f 1) = 0.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
f (f 1) = 0
Coq < replace (f 1) with 0.
2 subgoals
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
f 0 = 0
subgoal 2 is:
0 = f 1
What happened here is that the replacement left the first subgoal to be
proved, but another proof obligation was generated by the f10 is assumed
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
f (f 1) = 0
2 subgoals
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
f 0 = 0
subgoal 2 is:
0 = f 1
replace
tactic, as the second subgoal. The first subgoal is solved immediately
by applying lemma foo; the second one transitivity and then
symmetry of equality, for instance with tactics transitivity and
symmetry:
Coq < apply foo.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
0 = f 1
Coq < transitivity (f 0); symmetry; trivial.
Proof completed.
In case the equality t=u generated by 1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
0 = f 1
Proof completed.
replace u with
t is an assumption
(possibly modulo symmetry), it will be automatically proved and the
corresponding goal will not appear. For instance:
Coq < Restart.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
f (f 1) = 0
Coq < replace (f 0) with 0.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
f (f 1) = 0
Coq < rewrite f10; rewrite foo; trivial.
Proof completed.
Coq < Qed.
rewrite f10 in |- *; rewrite foo in |- *; trivial.
L2 is defined
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
f (f 1) = 0
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
f (f 1) = 0
Proof completed.
Coq < Qed.
L2 is defined
1.5 Using definitions
The development of mathematics does not simply proceed by logical argumentation from first principles: definitions are used in an essential way. A formal development proceeds by a dual process of abstraction, where one proves abstract statements in predicate calculus, and use of definitions, which in the contrary one instantiates general statements with particular notions in order to use the structure of mathematical values for the proof of more specialised properties.
1.5.1 Unfolding definitions
Assume that we want to develop the theory of sets represented as characteristic predicates over some universeU. For instance:
Coq < Variable U : Type.
U is assumed
Coq < Definition set := U -> Prop.
set is defined
Coq < Definition element (x:U) (S:set) := S x.
element is defined
Coq < Definition subset (A B:set) := forall x:U, element x A -> element x B.
subset is defined
U is assumed
set is defined
element is defined
subset is defined
Now, assume that we have loaded a module of general properties about relations over some abstract type
T, such as transitivity:
Coq < Definition transitive (T:Type) (R:T -> T -> Prop) :=
Coq < forall x y z:T, R x y -> R y z -> R x z.
transitive is defined
Now, assume that we want to prove that
subset is a transitive
relation.
Coq < Lemma subset_transitive : transitive set subset.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
In order to make any progress, one needs to use the definition of
transitive. The unfold tactic, which replaces all
occurrences of a defined notion by its definition in the current goal,
may be used here.
Coq < unfold transitive.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
forall x y z : set, subset x y -> subset y z -> subset x z
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
Now, we must unfold
subset:
Coq < unfold subset.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
forall x y z : set,
(forall x0 : U, element x0 x -> element x0 y) ->
(forall x0 : U, element x0 y -> element x0 z) ->
forall x0 : U, element x0 x -> element x0 z
Now, unfolding 1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
forall x y z : set,
element would be a mistake, because indeed a simple proof
can be found by auto, keeping element an abstract predicate:
Coq < auto.
Proof completed.
Proof completed.
Many variations on
unfold are provided in Coq. For instance,
we may selectively unfold one designated occurrence:
Coq < Undo 2.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
Coq < unfold subset at 2.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
forall x y z : set,
subset x y -> (forall x0 : U, element x0 y -> element x0 z) -> subset x z
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
forall x y z : set,
One may also unfold a definition in a given local hypothesis, using the
in notation:
Coq < intros.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
x : set
y : set
z : set
H : subset x y
H0 : forall x : U, element x y -> element x z
subset x z
Coq < unfold subset in H.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
x : set
y : set
z : set
H : forall x0 : U, element x0 x -> element x0 y
subset x z
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
x : set
y : set
z : set
H : subset x y
subset x z
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
x : set
y : set
z : set
subset x z
Finally, the tactic
red does only unfolding of the head occurrence
of the current goal:
Coq < red.
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
x : set
y : set
z : set
Coq < auto.
Proof completed.
Coq < Qed.
unfold transitive in |- *.
unfold subset at 2 in |- *.
intros.
unfold subset in H.
red in |- *.
auto.
subset_transitive is defined
1 subgoal
P : nat -> Prop
Q : nat -> Prop
f : nat -> nat
foo : f 0 = 0
f10 : f 1 = f 0
U : Type
x : set
y : set
z : set
Coq < auto.
Proof completed.
Coq < Qed.
intros.
unfold subset in H.
red in |- *.
auto.
1.5.2 Principle of proof irrelevance
Even though in principle the proof term associated with a verified lemma corresponds to a defined value of the corresponding specification, such definitions cannot be unfolded in Coq: a lemma is considered an opaque definition. This conforms to the mathematical tradition of proof irrelevance: the proof of a logical proposition does not matter, and the mathematical justification of a logical development relies only on provability of the lemmas used in the formal proof.Conversely, ordinary mathematical definitions can be unfolded at will, they are transparent.
