Related Tools
Software Verification
Several tools are being built on top of Coq, for software verification purposes.
  • Why is a verification conditions generator back-end.
  • Krakatoa is a Java code certification tool that uses both Coq and Why to verify the soundness of implementations with regards to the specifications.
  • Caduceus is a verification tool for C programs, built on top of Why.
  • Concoqtion is a dependently-typed extension of Objective Caml (and of MetaOCaml) with specifications expressed and proved in Coq.
  • Ynot is an extension of Coq providing a "Hoare Type Theory" for specifying higher-order, imperative and concurrent programs.
  • Ott is a tool to translate the descriptions of the syntax and semantics of programming languages to the syntax of Coq, or of other provers.
  • LNgen is a tool for generating Coq code for the infrastructure associated with a locally nameless representation;
  • Rainbow automatically generates Coq proofs from termination certificates.
Graphical User Interfaces
Coq can be used in text mode or in graphical mode using its gtk-based integrated development interface CoqIde. Alternative third-party graphical interfaces are also available :
Browsing, Searching and Documentation Tools
