Coq 8.7
The previous version: Coq 8.7
This version features:
  • A large amount of work on cleaning and speeding up the code base, notably the work of Pierre-Marie Pédrot on making the tactic-level system insensitive to existential variable expansion, providing a safer API to plugin writers and making the code more robust.
  • New tactics:
    • Variants of tactics supporting existential variables eassert, eenough, etc. by Hugo Herbelin;
    • Tactics extensionality in H and inversion_sigma by Jason Gross;
    • specialize with accepting partial bindings by Pierre Courtieu.
  • Cumulative Polymorphic Inductive Types, allowing cumulativity of universes to go through applied inductive types, by Amin Timany and Matthieu Sozeau.
  • The SSReflect plugin by Georges Gonthier, Assia Mahboubi and Enrico Tassi was integrated (with its documentation in the reference manual) by Maxime Dénès, Assia Mahboubi and Enrico Tassi.
  • The coq_makefile tool was completely redesigned to improve its maintainability and the extensibility of generated Makefiles, and to make _CoqProject files more palatable to IDEs by Enrico Tassi.
A lot of other changes are described in the CHANGES file.
This is the second release of Coq developed on a time-based development cycle. Its development spanned 9 months from the release of Coq 8.6 and was based on a public road-map. It attracted many external contributions. Code reviews and continuous integration testing were systematically used before integration of new features, with an important focus given to compatibility and performance issues.
For downloads (in particular to get installers for Windows and Mac OS, or a tarball of the sources), please go to the release page on GitHub.
Previous and development versions of Coq
The previous stable release of the Coq system is version 8.6.
The development version of Coq is browsable and downloadable from our Git repository using command: git clone https://github.com/coq/coq.git. The daily level of stability of this version can be observed at the bench-clone-coq site.
Most of the previous versions of Coq are available here.
