Creating and Submitting a Package
This page contains instructions to submit a simple example Coq package
called foo
at version 1.0.0
The full documentation on Opam packages can be found on the
Opam web site.
Package layout
For simplicity, we will assume that the Coq project you want to package
contains a Makefile
providing the following commands:
make # Build the package
make install # Install the package
Click here to see a minimal example Makefile
build: Makefile.coq
$(MAKE) -f Makefile.coq
install: Makefile.coq
$(MAKE) -f Makefile.coq install
Makefile.coq: _CoqProject
coq_makefile -f _CoqProject -o $@
See also the Reference Manual on
building a Coq project with coq_makefile
1.0.0
version of your project:
git tag 1.0.0
git push origin 1.0.0
If your repository is on GitHub at $YOU/foo
(where $YOU
is
your GitHub user name), the archive corresponding to the tag 1.0.0
can be downloaded from this URL:
https://github.com/$YOU/foo/archive/1.0.0.tar.gz
, using
curl -L
or your browser for example.
The Opam archive for Coq
Opam packages live in this repository: opam-coq-archive. New packages are submitted through GitHub.
Clone the repository
Follow this section if this is your first submission to the Opam archive to Coq.
First, go to the GitHub page of opam-coq-archive and make a fork.
The repository is now available in your personal GitHub space.
Clone it locally by typing the following, where $YOU
is your GitHub user name.
The correct URL in the third line can also be found by clicking on the
clone or download button on the GitHub page of your fork.
This creates a clone with two remotes, one for the official archive,
called upstream
, and one for your fork, called origin
git clone https://github.com/coq/opam-coq-archive -o upstream
cd opam-coq-archive
git remote add origin https://github.com/$YOU/opam-coq-archive
Update the repository
If you already have a clone of opam-coq-archive
, for example
because this is not your first submission, the following command updates
the upstream
remote with all changes since your last update
or initial clone.
git fetch upstream
Create a package definition file
Create a new branch named coq-foo.1.0.0
based on
upstream/master
git checkout -b coq-foo.1.0.0 upstream/master
In the opam-coq-archive
directory, create a sub-directory named as follows:
mkdir -p released/packages/coq-foo/coq-foo.1.0.0
The Opam package is thus named coq-foo
and the sub-directory name
is the package name followed by a dot followed by the version of the
package.
In that directory, create a text file called opam
which will contain the package's metadata (build instructions, dependencies, etc.).
Here is a template for released/packages/coq-foo/coq-foo.1.0.0/opam
opam-version: "2.0"
synopsis: "A Coq library doing wonders" # One-line description
description: """
Foo does bar with baz.
""" # Longer description, can span several lines
homepage: "https://github.com/$YOU/foo"
dev-repo: "git+https://github.com/$YOU/foo.git"
bug-reports: "https://github.com/$YOU/foo/issues"
doc: "https://$YOU.github.io/foo/"
maintainer: "your@email.address"
authors: [
"You"
license: "MIT" # Make sure this is reflected by a LICENSE file in your sources
depends: [
"coq" {>= "8.7" & < "8.10~"}
build: [
[make "-j%{jobs}%"]
install: [
[make "install"]
url {
src: "https://github.com/$YOU/foo/archive/1.0.0.tar.gz"
checksum: "sha256=133f2c6de1b9b35c0b26ab3e21fa86a351fffb415d20cae714b015f95fbc3725"
tags: [
"keyword:fooish"
"category:Miscellaneous/Coq Extensions"
"date:2019-07-01"
"logpath:Foo"
The last two fields are of particular interest:
The
url
section describes where to find your package. It must have at least the following fields: thesrc
field with the URL of the package archive, and thechecksum
field with the checksum of that archive prefixed bysha256=
The
tags
field contains Coq-specific metadata. See also the CEP on Opam metadata.
For a description of the other fields, see the relevant section of the Opam Manual.
The checksum can be obtained with:
curl -L https://github.com/$YOU/foo/archive/1.0.0.tar.gz | sha256sum
In the opam
file, the checksum must be prefixed with the
hashing algorithm, here sha256=
. (sha512=
, and
md5=
are also supported.)
Commit the new opam
file:
git add released/packages/coq-foo/coq-foo.1.0.0/opam
git commit -m 'Package coq-foo.1.0.0'
Test your new package
The preliminary step is to lint your opam
file as follows
opam lint --check-upstream released/packages/coq-foo/coq-foo.1.0.0/opam
Once no more errors are given, the best way to test your package is to add your
local clone of opam-coq-archive
to opam as follows, and then run opam
install
on your new package in verbose mode:
opam repo add test ./released
opam install -v coq-foo
If things go wrong, after having fixed the problem and before trying again
to install the package, run opam update
Submit your new package
Submission happens by creating a pull request on the opam-coq-archive repository.
First push your changes to your personal fork:
git push origin coq-foo.1.0.0
Then visit the GitHub page of your personal fork and click on the new pull request button.
Making good packages
Conventions
- The archive follows a layout.
Regular packages shall be placed in the
released
directory. One can also write packages that install development branches of a software. In that caseextra-dev
directory has to be used and the version has to end indev
likemybranch.dev
. - The package name should start with
coq-
, for examplecoq-color
orcoq-interval
. - The
tags
field in theopam
file can contain additional metadata (like a categorization or the Coq logical path the package populates) as described in CEP3
Rules of thumb
The released repository shall contain software that works with a stable version of Coq. Packages are maintained by their corresponding authors or by the Coq team. Dependencies must be expressed in a conservative way providing both lower and upper bounds to version numbers. This way all installable packages (i.e. with satisfiable constraints) shall compile successfully.
We advise package authors to make sure that the following conditions are met:
- Includes a Changelog that lists the main changes between any two versions part of this archive
- The License must allow free redistribution (even if it is not a free software license)
- No Admitted proofs
- All Axioms used are documented
- ML code is reviewed by a Coq developer
- Documentation should be available (see the
doc:
field in the Opam metadata)
In any case the Coq development team keeps the right to refuse the integration of a package or remove any package at any time.
Updating a package to a new version
- Like the initial version, the new version of the package should be submitted in a pull request and is encouraged to follow the guidelines above
- We recommend to ease the transition from the old to the new version by providing a transition strategy (a document helping a user to perform the switch: e.g. documenting all renamings).
- The old version stays in the repository.
