Template vs. “full” universe polymorphism
Main contributors
Sébastien Michelland, Yannick Zakowski.
Summary
Universe polymorphism in Coq is a thorny subject in general, in the sense that it's rather difficult to approach for non-experts. Part of it is due to the fact that Coq hides most things universes by default. For jobs that don't need universe polymorphism, Coq does the right thing basically all the time with no user input, which is fantastic. However, when universe polymorphism is needed and you, as a user, need to get into it, the hidden mechanisms tend to work against you. So let's unpack that.
Coq provides two mechanisms to support universe polymorphism in a broad sense. The historically first mechanism implemented is named “template polymorphism”. Nowadays, “proper” universe polymorphism is also supported. Unfortunately, numerous definitions in the standard library, such as the product type, are defined as template polymorphic, which may lead to troubles: in this tutorial, we illustrate when and where things can go wrong.
We'll first go through examples of monomorphic (i.e., fixed) universes to explain the initial problem. From there, showing what template universe polymorphism does and why it's not enough is actually fairly straightforward. This eventually leads to universe polymorphism as a more general solution.
Contents
  • 1. Quick reminder about universes
  • 2. Some issues with monomorphic universes
  • 3. What template universe polymorphism does and doesn't do
    • 3.1. Principle
    • 3.2. Breaking cycles with template polymorphism
    • 3.3. Template polymorphism doesn't go through intermediate definitions
  • 4. A taste of “full” universe polymorphism
    • 4.1. Principle
    • 4.2. Universe polymorphic definitions
Prerequisites
Needed:
  • The reader should have a basic understanding of universes. There is a reminder below but not at all a complete explanation.
Not needed:
  • Experience with universe polymorphism.
Installation: No plugins or libraries required.
A basic understanding of universes would be best to read this tutorial, but just in case here's a quick recap'.
The reason for universes is that there is no obvious type that can be assigned to the term Type. You can decide not to give it a type (in which case the calculus has more or less two kinds, values and types, like in Haskell). But if you decide to give it one, as the Calculus of Constructions does, you cannot make it Type itself, because Type: Type leads to logical inconsistencies known as Girard's paradox. (Check Type might appear to say that, but there are universes hidden there that Coq only prints if you ask for Set Printing Universes, as we'll see.)
The basic idea for universes is to organize types into a hierarchy. Usual datatypes such as natural numbers or strings have as type the bottom element in the hierarchy, Type@{0}. The type of Type@{0} is the next element Type@{1}; the type of Type@{1} is Type@{2}, and so on, with the typing rule Type@{i}: Type@{i+1} (infinitely). The type-to-element relation is well-founded, which salvages consistency. The integer associated with each element of the hierarchy is called a universe level or universe for short.
In Coq, Type@{0} is written Set for historical reasons. The word Type on its own doesn't refer to any particular universe level; instead, it means something closer to Type@{_} where Coq infers a universe level based on context, which can be confusing. This is why any job that involves inspecting universes requires Set Printing Universes, and why here we'll will write most universes explicitly.
Beyond checking the types of sorts, universes above 0 appear as a result of quantification. As a naïve intuition, any term that quantifies over types lives in a universe higher than 0. For example, the sort of base values like 73 is Type@{0} since 73: nat: Type{0}. However, the sort of a basic list type constructor list will be Type@{1}, following the judgement list: Type@{0} Type@{0}: Type@{1}.
Coq implements a rule called cumulativity (which is independent from the CoC) which extends the judgement of universes to Type@{i}: Type@{j} for i < j. This makes it so that higher universes as essentially “larger” than lower universes, as if the lower universes were literally included in the higher ones.
All of this results in the following basic rule: wherever a type in universe Type@{j} is expected, you can provide a type from any universe smaller than j, i.e. that lives in Type@{i} with i j. This is the main criterion that one has to care about when testing and debugging universes.
Let's see this in action by looking at a completely monomorphic definition of a product type, i.e., one that lives in a single fixed universe. As mentioned before, Coq tries pretty hard to hide universes from you. One of the consequences is that we need Set Printing Universes to see anything we're doing.
Open Scope type_scope.
Set Printing Universes.
Let us create a variable uprod representing a universe level, and then the product of two types living in universe uprod.
Universe uprod.
Inductive mprod (A B: Type@{uprod}) := mpair (a: A) (b: B).
For simplicity we're using the same universe level for both A and B; this is irrelevant to the issues below.
About mprod.
uprod is a fixed universe, and so the basic rule applies: we can use it with any type that lives in a lower universe, but we can't use it with a type that lives in a higher universe.
Check (fun (T: Type@{uprod}) ⇒ mprod T T).
Fail Check (fun (T: Type@{uprod+1}) ⇒ mprod T T).
You might think that uprod has to be a specific concrete integer so that universe consistency checks can be performed during typing. However, we can satisfy CoC rules without assigning specific integers and keep universes like uprod symbolic as long as there exists a concrete assignment that keeps things well-typed.
Coq uses these so-called “algebraic” universes: a universe number is either a symbol (e.g. uprod), the successor of a symbol (e.g. uprod+1), or the max of two levels (e.g. max(uprod, uprod+1)). Counter-intuitively, we actually cannot specify universes directly by numbers.
Check Type@{uprod}.
Check Type@{uprod+1}.
Check Type@{max(uprod, uprod+1)}.
(* Check Type@{10}. *)
(* Error: Syntax error: '_' '}' or universe expected after '@{' (in sort). *)
The operators +1 and max arise from typing rules; the important part is that these are the only ones needed to implement all the rules. The calculus of integers with +1, max, and < is decidable and thus it's possible for Coq to carry out universe consistency checks using these algebraic universes without assigning concrete numbers.
Instead, when you use a term of type Type@{i} where a term of type Type@{j} is required, Coq checks that the constraint i j is realizable: if it is, the constraint is recorded and the term is well-typed; otherwise a universe inconsistency error is raised.
For instance if we instantiate mprod with a Set, we get Set uprod, because a type at level uprod was expected and we provided one at level Set. The constraint is realizable so the definition is accepted.
Check (mprod (nat: Set)).
If we instantiate with a Type at level 1, we get the stronger constraint Set < uprod. It's still realizable, so the definition typechecks again; however, all future definitions must be compatible with the constraint, otherwise there will be a universe inconsistency.
Check (fun (T: Type@{Set+1}) ⇒ mprod T).
What we have to accept now is that we're never getting a concrete value out of that universe uprod: it's always going to remain a variable, and it will only evolve in its relations with other universe variables, i.e. through constraints.
The core limitations of template universe polymorphism are related to when it doesn't activate and leaves you with monomorphic universes, so we can demonstrate most of the issues directly on monomorphic universes.
Let's introduce a new universe u. Initially u and uprod are unrelated, which we can see by printing the section of the constraint graph that mentions these two universes. (Note that we don't care about the Set < x constraints; all global universes have it.)
Universe u.
Print Universes Subgraph (u uprod).
Now if we instantiate mprod with a Type@{u}, we get a new constraint that u uprod. Note that this constraint is global, so it now affects typing for all remaining code!
Definition mprod_u (T: Type@{u}) := mprod T T.
(This is one of the reasons why universes can be difficult to debug in Coq: any use of a definition might impact universe constraints, so importing certain combinations of modules, adding debug lemmas, or any other change in global scope can affect whether code ten files over typechecks.)
This constraint changes if we now try to use mprod with a Type@{u+1}.
Definition mprod_up1 (T: Type@{u+1}) := mprod T.
This is a pretty artificial example, but as mentioned in the introduction universe bumps occur naturally due to quantification. For example, let's say we want a “lazy” value wrapper that stores values through unevaluated functions.
Inductive lazyT: Type Type :=
  | lazy {A: Type} (f: unit A): lazyT A.
lazy contains a universe bump: due to quantification, the types that we provide for A will have to live in strictly smaller universes than the associated lazyT. This is not required by the type itself...
About lazyT.
(* lazyT : Type@{lazyT.u0} -> Type@{max(Set,lazyT.u1+1)} *)
But it is required by the lazy function, which takes a lazyT.u1, thus smaller than lazyT which lives at level lazyT.u1+1.
About lazy.
(* lazy : forall {A : Type@{lazyT.u1}}, (unit -> A) -> lazyT A *)
Note that the bump only exists because lazy quantifies on A. In this simple example, we could make A a parameter of the inductive instead of an index and avoid the bump, but it's not the case in general (e.g., the freer monad or functor laws).
We can see this in a universe constraint if we bring them both in a single definition, such as the very natural lazy_pure function below. A universe variable lazy_pure.u0 is introduced for A, and since we supply A as (implicit) argument to lazy's A argument which lives in universe level lazyT.u1, we get lazy_pure.u0 lazyT.u1.
Since lazyT itself lives at level lazyT.u1+1, the new constraint lazy_pure.u0 lazyT.u1 implies a strict inequality between the universes of A and lazyT A.
Definition lazy_pure {A: Type} (a: A): lazyT A := lazy (fun _a).
Print Universes Subgraph (lazy_pure.u0 lazyT.u0 lazyT.u1).
We run into the typical limitation of monomorphic universes if we now happen to want products in these two places at once:
  • Products as arguments to lazyT (enforcing uprod lazyT.u1)
  • lazyT within products (enforcing lazyT.u1+1 uprod).
This is a very common thing to want, especially when passing values around as products, which happens all the time.
Currently we don't have any constraint between lazyT.u1 and uprod.
Print Universes Subgraph (lazyT.u1 uprod).
If we were now to use mprod in a lazyT, we'd get uprod lazyT.u1.
Definition lazy_pure_mprod {A B: Type} (a: A) (b: B): lazyT (mprod A B) :=
  lazy_pure (mpair _ _ a b).
Conversely, if we used lazyT in mprod, we'd get lazyT.u1 < uprod. Because we've defined lazy_pure_mprod, this is inconsistent with existing constraints, so the definition doesn't typecheck!
Fail Definition mprod_lazy {A B: Type} (a: A) (b: B):
    mprod (lazyT A) (lazyT B) :=
  mpair _ _ (lazy_pure a) (lazy_pure b).
This definition would have been accepted had we not defined lazy_pure_mprod just prior. In fact, we can have either one of these definitions, but we can't have both. Which is typically how you get to errors appearing or disappearing based on what modules have been imported and in what order, a.k.a., everyone's favorite.
Principle
Template universe polymorphism is a middle-ground between monomorphic universes and proper polymorphic universes that allows for some degree of flexibility. We can see it mentioned in the description of prod from the standard library; About says "prod is template universe polymorphic on prod.u0 prod.u1". This has no effect on the printed type, because it only affects instances.
About prod.
Now, remember how mprod lives at level uprod all the time? This shows if we instantiate it with any random type: we get mprod T T: Type@{uprod}.
Check (fun (T: Type) ⇒ mprod T T).
Now the same with the standard prod gives us a slightly different result.
Check (fun (T: Type) ⇒ T × T).
Ignoring the fact that prod has two separate universes for its arguments, the real difference is that T × T lives in the same universe as T (which is called Type@{Top.N} or Type@{JsCoq.N} for some N, depending on the environment in which you're running this file), not in a fixed universe like uprod. We could also instantiate prod with propositions or sets and the resulting product would correspondingly live in Prop or Set.
Check (fun (P: Prop) ⇒ P × P).
Check (fun (S: Set) ⇒ S × S).
In other words, prod can live in different universes depending on what arguments it is applied to, making it “universe polymorphic” in a certain sense. You can think about it as being parameterized over universe levels, with the constraint that the input levels must be below prod.u0 and prod.u1 respectively.
It looks like we've solved our universe problem now because we can have both definitions of prod within lazyT and lazyT within prod.
Definition lazy_pure_prod {A B: Type} (a: A) (b: B): lazyT (A × B) :=
  lazy_pure (pair a b).
Definition prod_lazy {A B: Type} (a: A) (b: B): lazyT A × lazyT B :=
  pair (lazy_pure a) (lazy_pure b).
The constraints are not gone: it's just that now the two instances of prod live in different universes:
  • In lazy_pure_prod, A and B live in lazy_pure_prod.u0 and lazy_pure_prod.u1 respectively; prod lives in the max of both which must be lower than lazyT.u1, meaning lazy_pure_prod.{u0,u1} lazyT.u1.
  • In prod_lazy, lazyT A × lazyT B is built out of two types in lazyT.u1+1, meaning that lazyT.u1 < prod.{u0,u1}.
  lazyT.u1 prod.u0 prod.u1
  lazy_pure_prod.u0 lazy_pure_prod.u1
  prod_lazy.u0 prod_lazy.u1).
There are other constraints here but they're unrelated to the inconsistency that we had with the monomorphic version.
And thus, the problem is solved... but only when the universe at fault comes from an inductive type directly (here, prod). Template polymorphic universes don't propagate to any other derived definition. So if we define the state monad for example, it will not itself be universe polymorphic at all, and thus it will exhibit the same behavior as mprod.
Definition state (S: Type) := fun (T: Type) ⇒ S (S × T).
About state.
state.{u0,u1} correspond to the old uprod: the type of T is monomorphic. Notice how About state doesn't say that state is template universe polymorphic, while it does for prod. So now the issue from earlier comes up again.
Definition state_pure {S T: Type} (t: T): state S T := fun s(s, t).
Definition lazy_pure_state {S T: Type} (t: T): lazyT (state S T) :=
  lazy_pure (state_pure (S := S) t).
Fail Definition state_lazy {S T: Type} (t: T): state S (lazyT T) :=
  state_pure (S := S) (lazy_pure t).
Tricks to bypass the limitations of template universe polymorphism generally consist in exposing the template-polymorphic inductive, prod in this case, in order to get a fresh universe from it. Two examples are:
  • Inlining: expanding the definition of state in the examples above exposes prod which generates fresh universe levels. This doesn't prevent Coq from later matching/unifiying the expanded term with the original state, so it usually works as long as you can dig deep enough to find the problematic inductive. Of course, this comes at the cost of breaking any nice abstractions you might have.
  • Eta-expansion: writing prod without arguments doesn't generate fresh universes for the purpose of template polymorphism, so eta-expanding to fun A B prod A B can help relax universe constraints.
These limitations are rather annoying because constructions based on prod are everywhere in the standard library and in projects. The state monad is just one in a million. It's also the same problem with sum and many other core types like list.
About sum.
About list.
Principle
Template universe polymorphism is limited in that it only applies to inductives and any indirect uses of such a type are just monomorphic. The proper way to have universe polymorphism is to allow it on any definition so that quantification can remain when defining things like state.
Universe polymorphism extends the language of universes with universe parameters, which are similar to universe variables except that they are quantified over by definitions.
We can enable universe polymorphism from here onward with Set Universe Polymorphism. We need it on basically every type and definition.
Inductive pprod (A B: Type) := ppair (a: A) (b: B).
About pprod.
Notice how pprod has universe parameters u and u0. We can instantiate pprod with different such parameters and this will yield many variations of the same definition in as many universes.
So far, this is the same as template universe polymorphism.
The new trick is that definitions derived from pprod can retain the polymorphism by having their own universe parameters.
Definition pstate (S: Type) := fun (T: Type) ⇒ S (pprod S T).
About pstate.
Now pstate also has universe parameters and the expressiveness of pprod is no longer lost.
Definition pstate_pure {S T: Type} (t: T): pstate S T := fun sppair _ _ s t.
Definition lazy_pure_pstate {S T: Type} (t: T): lazyT (pstate S T) :=
  lazy_pure (pstate_pure (S := S) t).
Definition pstate_lazy {S T: Type} (t: T): pstate S (lazyT T) :=
  pstate_pure (S := S) (lazy_pure t).
This solution completely solves the state issue from our running example... with the drawback of redefining the product type, which creates friction with the standard library.
