Basic library files and modules management
Summary
Table of content
- 1. Library files, modules and identifiers
- 1.1 The Require command and fully qualified names
- 1.2. Basic modules and the Import command
- 1.3. Name clashes and disambiguation
- 1.4. Other content types in modules
- 1.5. Guidelines about the order of Require and Import commands
- 2. Fine control over module features
- 2.1. On the user's side: selective import
- 2.2. On the writer's side: locality attributes in modules
- 3. The Export command
Prerequisites
- The user should already have some basic Coq experience: writing definitions, lemmas, proofs...
- Some parts deal with more advanced Coq content (user-defined tactics, notations, coercions...); having some basic knowledge about it is better to appreciate what Coq can offer, but is not really needed.
Print Libraries.
As we can see, these files share a common logical prefix made of:
This means that the Init directory contains the (compiled) files
Notations.vo, Ltac.vo, Logic.vo, ... and we can already use their
content, for instance the commutativity of the disjunction:
- Coq: the library prefix used by the standard library
- Init: the subdirectory of the root directory of Coq's standard library where these library files are located
Let's require another small library file.
The previous command told Coq to load all logical and computational
content in the file Bool.vo contained in the directory Bool of the root
directory of Coq's standard library (the interested reader can browse its
current
source code).
Now let's see how our list of libraries has evolved:
Print Libraries.
As we can see, we have not one but two more library files.
The Coq.Classes.DecidableClass is itself required in Coq.Bool.Bool.
Now there are two very important message here:
1. When we Require a file, we Require recursively any file it has
Required (and any file Required in the Required files, and so on).
2. There is **no way** to "unrequire" anything. Once a file has been
required, its content will remain in the global environment of the user
in every file where it was (transitively) required, possibly cluttering
up Search output.
As a consequence, one should be careful of what one Requires.
Now that we have required Coq.Bool.Bool, we have many more lemmas about
boolean operations.
Some of them are qualified with the Bool. prefix, these come from
Coq.Bool.Bool. Others have short names, these come from one of the
Coq.Init files.
Using the About command gives us their locations.
Now let's take a look at Bool.andb_true_l
We see that it expands to Coq.Bool.Bool.andb_true_l. This is the internal
name Coq uses to distinguish it from any other constant.
We call it an absolutely qualified identifier or fully qualified
identifier.
This is a technical but important notion, so we should take some time to
describe this identifier. There are several parts separated by dots.
Now, at this point, Coq.Bool.Bool is the last required library file
called Bool containing a constant named andb_true_l, so Coq accepts
(and prints) as a shorter partially qualified the identifier
Bool.andb_true_l.
Another valid partially qualified identifier for the same constant is
All these identifiers refer to the same constant:
- The first part is Coq: it is the logical name of the library. Other mechanisms (for instance a _CoqProject file, or -R and -Q options for coqc, locations which are known by coqc, such as the output of coqc -where, ...) associate a logical name to a physical directory in the user's system which is the root directory of this library.
- The second and third part correspond to the path of the file (relative to the root of the library) containing the identifier in the given library, in our case, on a Unix family system, it corresponds to Bool/Bool.vo.
However, at this point Coq does not accept the unqualified andb_true_l as
a valid identifier:
Fail Check andb_true_l.
Coq does not allow us to use this short name automatically because it
risks to silently shadow another constant with the same short name.
The Locate command shows all constants associated to an unqualified
identifier and how to refer to it in the shortest way possible.
Locate andb_true_l.
If we want to use such a short name, we need to Import the Bool
module (yes, we said module here and not library file, more about this
later).
Now we can refer to the constants in Bool with their short names.
Coq will also display short names in its messages:
In passing, we have Imported Bool with a small unqualified name because
there was no confusion:
Locate Bool.
But we can refer to the Bool with a more qualified name too:
About Bool.Bool.
About Coq.Bool.Bool.
In fact, most users prefer short names to fully qualified names so, in
practice, one usually Requires and Imports a file at the same time.
This is done, for instance, with the syntax:
From Coq Require Import Bool.Bool.
In passing, there are many more possibilities to Require (with or with
Import) a library file.
The fully qualified name of this file is Coq.Bool.Bool, and one can
factor any prefix in the From part of the command, so the following
command achieves the same goal:
From Coq.Bool Require Import Bool.
or, with an empty From part:
Require Import Coq.Bool.Bool.
In fact, the From part is mostly a convenience to require multiple parts
from a common library or sublibrary. For instance, if one uses the mathcomp
library, the single line:
From mathcomp Require Import ssreflect ssrfun ssrbool eqtype ssrnat seq.
loads and imports 6 files from the mathcomp library.
If there is no confusion, it is even possible to omit the directory (or
directories) part. In our case there is only one file Bool.vo in all
Coq's standard library, so we could also have used
What to choose is then mostly a matter of taste (and clearly depends on the
number of files in the library).
We will use modules here mostly because they will help us understand how
to get what we want from library files (and reject, if possible, what we
don't want).
For now let us consider a very simple module:
Module Foo.
Definition foo := 42.
Lemma bar : 21 × 2 = foo.
Proof. reflexivity. Qed.
Lemma baz : 21 + 21 = foo.
End Foo.
End Foo.
Such a module, written down explicitly with End module_name at the end
is called an interactive module.
Our module Foo has 1 definition and 2 lemmas. It's printed out in the
following way:
Print Module Foo.
Notice that, surprisingly, the too lemmas are printed as Parameters, but
they really are actual lemmas.
We can access the content of the module with the dot syntax.
Foo.bar and Foo.baz are not Parameters or Axioms: the following
Print Assumptions commands show that they are "closed under the global
context", that is they do not rely on any axiom and are indeed proved.
But we cannot yet access them with short names:
Fail Check bar.
Locate bar.
Locate bar.
The content of the module Foo can be used just like any other definitions
and lemmas
Lemma forty : Foo.foo - 2 = 40.
Proof.
unfold Foo.foo.
fold Foo.foo.
rewrite <-Foo.bar.
reflexivity.
Qed.
Proof.
unfold Foo.foo.
fold Foo.foo.
rewrite <-Foo.bar.
reflexivity.
Qed.
This dot syntax is reminiscent of what we used for library files, and it is
no accident. In fact,
library files are modules.
This is the most important fact to take home from this tutorial, and the
main reason to study a part of Coq's module system.
We can even print the content of library files, viewed as modules:
Print Module Coq.Bool.Bool.
Import is actually a module command, so we can:
Now that Foo is Imported, we can access its content with short names:
To sum up without subtlety what we have learned so far:
When we Imported our Foo module before, there was no possible name
clash since no constant in our context were named foo, bar or baz.
In real life Coq, however, global contexts can be huge and there will
be name clashes.
So, what happens if we define and import the following module?
- We Require library files to load their content.
- We Import modules to use short names for their content (among other things we will see shortly)
- Library files are modules.
First, Coq emits no error or warning, so this is a legit operation.
What is foo now?
Our OtherFoo.foo identifier has actually shadowed Foo.foo.
To identify it, we now need to use a more qualified name.
The Locate command shows the list of identifiers whose unqualified name
is the given argument:
Locate foo.
The first item in the list is our OtherFoo.foo constant, it is available
by its short name. Next is Foo.foo and Coq gives us the shortest partially
qualified name to refer to it.
What happens if we now Import Foo again?
We have changed again to which constant refers the short name foo!
Our Foo.foo constant is now the first item in our list of foo constants.
This changing short name resolution may look innocuous but it has a very
important consequence:
The order of the Import commands matters, changing it can break things.
Notice that one can always use more qualified names, so that the resulting
code is independent of the Import orders:
Print Foo.foo.
Print OtherFoo.foo.
Print OtherFoo.foo.
Now, for a real life example, let us consider the library files
Coq.Arith.PeanoNat and Coq.ZArith.BinInt which contain the bulk
of Coq's standard library content for, respectively Peano natural numbers
and (binary) integers.
Most of the results and operations are actually contained in the interactive
(inner) modules PeanoNat.Nat and BinInt.Z. These inner modules are not
imported, yet.
Notice that the name add_0_r is used both for natural numbers and for
integers, which seems right.
At this point, add_0_r does not refer to anything.
Fail Check add_0_r.
Locate add_0_r.
Locate add_0_r.
We may choose to Import Nat if, for instance, our current development
deals more with natural numbers than integers.
We could even Import both modules, but then beware that the order is
important.
Another common choice is to Import neither of them and use the Nat. and
Z. prefixes as namespaces. This is a bit more verbose, but it is also
easier to read.
What happens if module names themselves clash?
We actually are already in that case:
About Nat.
About Coq.Init.Nat.
About Coq.Init.Nat.
We have one module named Nat in PeanoNat and another one in the form
of a library file in the Init directory.
The name of the module Coq.Init.Nat was shadowed when we
Imported the module Coq.Arith.PeanoNat.
As we have just seen, it suffices to qualify more the module which is
shadowed if we want to explicitly refer to it.
When two modules share the same name, there can be name clashes and
shadowing if some of their constants have the same name. Let us illustrate
it with nested modules.
The situation would be similar if we required two library files with the
same name in different libraries or directories (but we cannot illustrate
this case conveniently in a single-file tutorial).
Module NestedABC1.
Module ABC.
Definition alice := 1.
Definition bob := 1.
End ABC.
End NestedABC1.
Module NestedABC2.
Module ABC.
Definition alice := 2.
Definition charlie := 2.
End ABC.
End NestedABC2.
For now, there is no ambiguity, since we have not imported any module.
Our 4 new constants are:
- NestedABC1.ABC.alice
- NestedABC1.ABC.bob
- NestedABC2.ABC.alice
- NestedABC2.ABC.charlie
Locate alice.
Locate bob.
Locate charlie.
Locate bob.
Locate charlie.
Now we Import both outer modules:
What are ABC.alice, ABC.bob and ABC.charlie now?
Print ABC.alice.
Print ABC.bob.
Print ABC.charlie.
Print ABC.bob.
Print ABC.charlie.
As we see, ABC.alice from NestedABC1 has now been shadowed by
ABC.alice in NestedABC2. Other than that, Coq is perfectly fine with
ABC.bob, which means that the ABC prefix in these three identifiers
can actually refer to different modules.
Of course, we can still refer to the alice constant in the first module
with a more qualified identifier:
Locate alice.
Print NestedABC1.ABC.alice.
What happens if we Import both ABC momdules?
Anything more than what we already saw: the order of the Import commands
will determine the meaning of the short name alice.
The previous command did not shadow the module name ABC itself, so it
still refers to the previously Imported NestedABC2.ABC and we can
Import it that way:
Where is the other alice?
Locate alice.
To conclude this part, let us sum up what Coq allows and disallows regarding
identifiers:
So far, our module Foo contained only definitions and lemmas.
In practice there are many more content types in a module:
It is not an issue if some (or all) these categories are obscure to you.
We are only interested in what persists outside the module and in which
case. We will only experiment with some of these categories.
- it is possible to have two files with the same name as long as they are in different directories;
- it is possible to have two (non-file) modules with the same name as long as they are in different modules (which can be library files);
- it is possible to have two constants with the same name as long as they are in different modules (including library files)
1.4. Other content types in Modules
- parameters and axioms
- tactics
- notations, abbreviations, Ltac notations and Ltac2 notations
- hints and type class instances
- coercions
- canonical structures
Module Bar.
(* A parameter: *)
Parameter (secret : nat).
(* An axiom: *)
Axiom secret_is_42 : secret = 42.
(* A custom tactic: *)
Ltac find_secret := rewrite secret_is_42.
(* An abbreviation: *)
Notation add_42 := (Nat.add 42).
(* A tactic notation: *)
Tactic Notation "fs" := find_secret.
(* A notation: *)
Infix "+p" := Nat.add (only parsing, at level 30, right associativity) : nat_scope.
(* Two lemmas: *)
Lemma secret_42 : secret = 42.
Proof. find_secret. reflexivity. Qed.
Lemma baz : 21 +p 21 = secret.
Proof. fs. reflexivity. Qed.
End Bar.
We have not imported Bar yet. What do we have?
About Bar.secret.
About Bar.secret_is_42.
Print Assumptions Bar.secret_is_42.
About Bar.secret_42.
Print Assumptions Bar.secret_42.
About Bar.baz.
Print Assumptions Bar.baz.
About Bar.baz.
We see that parameters, axioms and lemmas are available, and axioms are
treated as such after the end of the module.
What about the other content?
Print Bar.add_42. (* Our abbreviation is available. *)
Fail Check (21 +p 21). (* Our notation is not. *)
Lemma forty_two : Bar.secret = 42.
Proof.
Fail fs.
Fail Bar.fs. (* Our tactic notation is not available. *)
Bar.find_secret. (* But our tactic is. *)
reflexivity.
Qed.
Proof.
Fail fs.
reflexivity.
Qed.
As we can see, only the tactic `find_secret` and the abbreviation
add_42 were available. Now let's Import Bar:
To sum things up:
We have seen that the order of Require and Import statements is
important. Some constants could be shadowed by others, which can break
definitions and proofs.
In general, we should try to respect the following guidelines:
Now is a good time to present a recent addition: selective import of
modules. Recall that importing a module has basically two effects:
Selective import lets us precisely choose what we want to import.
To illustrate this, we create a hint database:
- constants (i.e. parameters, definitions, lemmas, axioms, etc), tactics and abbreviations contained in a module are available even if we do not Import a module, with a qualified name;
- notations, Ltac notations, Ltac2 notations need the module to be imported to be available (note that notations are also associated to notation scopes we may have to Open or delimit with a key in order to use them)
- the same holds for coercions, hints, type class instances and canonical structures (we omit the experiments for brevity).
1.5 Guidelines about the order of Require and Import commands
- All Require commands should (ultimately) be at the beginning of a file, it makes it easier to know on which theories the file is built. It is fine during development to experiment temporarily with Require commands in the middle of the file and in a final version, either move the require statement at the beginning of a file, or the whole experiment in a separate file.
- Usually, Require statements are actually Require Import statements: we want shorter names, notations, etc about theories we explicitly build on. Other constants which have been (implicitly) recursively Required need a longer name to be used, so it is easier not to use them by accident (or to finally decide that we need to explicitly Require Import other modules).
- We should Require Import only what is needed: it makes the global environment smaller, reduces the risks of shadowing and saves compilation time. In particular, breaking dependencies allows parallel compilation with multithreaded processors.
- In general, we should Require Import files from external libraries first, in a more or less specialization order (the most basic theories first). Then, we should Require Import other internal library files at the end. Doing so prevents an external project to break our file by shadowing internal constants we use in that file.
- We should try to Require Import files in the same order everytime to increase predictability of breakage due to shadowing.
- make the short names of constants (lemmas, definitions, ...), abbreviations and tactics available
- enable the other content: notations, tactic notations, hints, coercions and canonical
Create HintDb req_tut.
Our next example contains almost every categories of content:
Module Baz.
(* Constants: *)
Parameter b : nat.
Definition almost_b := 41.
Axiom b_rel : b = almost_b + 1.
Notation add_two := (fun x ⇒ x + 2).
(* A tactic: *)
Ltac rfl := reflexivity.
(* A notation: *)
Notation "x !!" := (x × 42) (at level 2) : nat_scope.
(* A coercion: *)
Coercion to_nat := fun (x : Z) ⇒ 42.
(* A hint (please _do not_ pay attention to the #[export] locality
attribute, it is here for compatibility reasons and will be discussed
in the next section) *)
#[export] Hint Rewrite b_rel : req_tut.
End Baz.
(* Constants: *)
Parameter b : nat.
(* A tactic: *)
(* A notation: *)
(* A coercion: *)
End Baz.
Let us import our notations first:
Everything else has not been imported.
Fail Check b.
Fail Check almost_b.
Fail Check b_rel.
Fail Compute (0%Z + 3). (* Our coercion is not there. *)
Print HintDb req_tut. (* Our hint database is sadly empty. *)
Fail Check b_rel.
Let us now import our coercions and hints with one command:
Import (coercions, hints) Baz.
Compute (0%Z + 3).
Print HintDb req_tut. (* Our hint is available *)
Lemma b_42 : Baz.b = 42.
Proof. autorewrite with req_tut. unfold Baz.almost_b. Baz.rfl. Qed.
Compute (0%Z + 3).
Our notation is still there:
In fact, it is important to understand that there is no way to "un-import"
anything in the same module or section. Once a module feature has been
activated, it remains so until the end of the current section or module (or
file), the only exception being shadowed content.
We call the coercions and notations seen before import categories.
The other import categories correspond to what we mentioned before, namely:
hints, canonicals, ltac.notations and ltac2.notations.
We can also select which constants and abbreviations are available
by their short names:
Import Baz(almost_b, b_rel, add_two).
Check almost_b.
Check b_rel.
Fail Check b.
Print add_two.
Fail Print rfl.
Print Baz.rfl.
Check almost_b.
Check b_rel.
Fail Check b.
Print add_two.
Fail Print rfl.
Print Baz.rfl.
There is also a way to tell Coq: Import everything except these
categories. We just need to prepend them with a minus sign:
Module OtherBaz.
Definition other_b := 42.
Definition almost_other_b := 41.
Definition almost_almost_other_b := 40.
Notation "x ??" := (x × 42) (at level 2) : nat_scope.
Coercion to_nat := fun (x : bool) ⇒ 42.
End OtherBaz.
Import -(coercions) OtherBaz.
Check almost_other_b.
Compute 10 ??.
Fail Check (true + 3).
End OtherBaz.
Compute 10 ??.
Notice that, when we import everything except some categories, it is not
possible, at the time of writing, to choose which identifiers are imported
to be available as short names: they all are.
We can always change our mind and decide to import a category we did not:
To end this section, we turn to inductive types.
Module Unary.
Inductive UnaryPos := one | successor (n : UnaryPos).
Inductive UnaryZ := zero | plus (n : UnaryPos) | minus (n : UnaryPos).
End Unary.
End Unary.
We have not imported anything yet.
Our inductive types and their constructors are available with their
qualified names:
So are our automatically generated induction principles (ending with
_sind, _ind, _rec or _rect):
We can selectively Import all these constants and abbreviations.
For an inductive type and its constructors, it suffices to give the type
in the constants parenthesized list to be able to use its short name
However, its constructors and induction principles are not imported:
It is possible to Import them manually:
But there is a shortcut: using UnaryPos(..) imports at once the type, as
well as its constructors and induction principles:
The following command enables all short names associated to the inductive
type UnaryZ:
- the #[local] attribute makes some content unavailable for import
- the #[export] attribute makes some content available only if the module is Imported
- the #[global] attribute, in some cases, makes some content available outside the module even when not Imported.
Module YetAnotherBaz.
#[local] Definition yet_another_b := 42.
Definition almost_yet_another_b := 41.
#[local] Definition almost_almost_yet_another_b := 40.
#[local] Notation "x %%" := (x × 42) (at level 2) : nat_scope.
#[local] Coercion to_nat := fun (x : Prop) ⇒ 42.
Compute 3 %%.
Compute (True + 2).
End YetAnotherBaz.
Import YetAnotherBaz.
Fail Check yet_another_b.
Check YetAnotherBaz.yet_another_b.
Check almost_yet_another_b.
Fail Compute (True + 2).
The notation "x %" is also unavailable, but we cannot show it without
stopping compilation, as it is not even parsed.
You can try it by uncommenting: Compute 3 %.
As we see, using the #[local] attribute in a module makes some content
unavailable for import, which means, for constants, to make them only
available with qualified names and for other categories (hints, coercions,
etc), to disable them outside the module.
This should be used without restraint on anything which should not be part
of the user's interface, e.g. convenience ad-hoc tactics or unstable
implementation details.
The #[export] attribute is not as well supported as #[local].
In fact, in a module, since Coq 8.18, it is either not supported, or the
default behavior (make a feature or short name available only when
a module is Imported), except when used with the Set command which is
used to change some Coq options.
Prior to Coq 8.18, if one wants Hints to be available if (and only if) the
module is Imported, they should have the #[export] attribute and in
Coq 8.17, Coq will emit a fatal warning they do not have any attribute.
The following example shows what to expect (in any recent Coq version)
when a Hint is kept local and a Set command has no attribute:
Module NotExported.
Set Universe Polymorphism.
#[local] Hint Rewrite Nat.add_1_r : req_tut.
Test Universe Polymorphism.
End NotExported.
Import NotExported.
Lemma add_ones_r (n : nat) : n + 1 + 1 + 1 = S (S (S n)).
Proof.
autorewrite with req_tut. (* This did _nothing_. *)
rewrite 3!Nat.add_1_r.
reflexivity.
Qed.
End NotExported.
Import NotExported.
Proof.
reflexivity.
Qed.
The option "Universe Polymorphism" is not set outside the module.
Now, here is the same module with #[export] locality attributes:
Module Exported.
#[export] Set Universe Polymorphism.
#[export] Hint Rewrite Nat.add_1_r : req_tut.
End Exported.
Import Exported.
Lemma add_ones_r' (n : nat) : n + 1 + 1 + 1 = S (S (S n)).
Proof.
reflexivity.
Qed.
End Exported.
Import Exported.
Proof.
reflexivity.
Qed.
As we saw, the #[export] locality attribute allowed us to Set our
option whenever the module is Imported.
For our hint, #[export] is the default attribute since Coq 8.18, but if
you need to work with older versions, you should add it to your Hints,
if you want them to be available after import.
Now, for the #[global] setting. Again, it is often not supported and when
it is, commands have the default behaviour (short names and features
disabled except when the module is Imported), except when Setting
options or with the Hint command (and typeclass instances): hints and
settings with the #[global] attributes persist outside of the module,
even if it is not Imported.
Let us restore the state of the Universe Polymorphism option:
Unset Universe Polymorphism.
Module SetGlobalExported.
#[global] Set Universe Polymorphism.
#[global] Hint Rewrite Nat.add_0_l Nat.add_0_r : req_tut.
Lemma this_is_a_cool_lemma (n : nat) : 0 + n + 0 + 0 = 0 + n.
Proof.
reflexivity.
Qed.
End SetGlobalExported.
Proof.
reflexivity.
Qed.
We didn't even import the module, and the setting is already there!
This should really be used with caution as it imposes our choice to any user
who Requires our library file.
Our hints have also been silently added to our database, even without
Import. Since hint databases have a tendency to make proofs very brittle
this should also be used with caution.
Proof.
reflexivity.
Qed.
Proof.
reflexivity.
Qed.
Exercise: why could we use the same name in the two previous lemmas?
3. Exporting a module
Module A.
Definition this_is_a := 0.
Module B.
Definition this_is_b := 42.
End B.
Fail Check this_is_b.
Import B.
Check this_is_b.
End A.
Module B.
End B.
Import B.
Check this_is_b.
End A.
This situation may seem contrived, but imagine rather a library file, say
A.v which Requires and Imports another library file, say B.v.
At this point, we are in a situation similar to being in yet another file
C.v which has Required the file A.v (but not yet Imported it).
We can access the content of A with qualified names.
Print A.this_is_a.
Print Module A.B.
Fail Print Module B.
Print A.B.this_is_b.
Fail Check A.this_is_b.
Print Module A.B.
If we Import A, we get short names for its content, including the module
B itself.
But, even though B is Imported in A, we cannot use a short name
for this_is_b:
Fail Print this_is_b.
Print B.this_is_b.
Print B.this_is_b.
This behaviour is actually very sane. Some programmers may have Imported
modules in library files for convenience, this should not affect every
users of their library.
Still, there is a way (and sometimes good reason) to both Import a module
(which could be a file) and mark it for importation whenever the current
module (or file) is Imported: we use the Export command.
Module A'.
Definition this_is_a' := 0.
Module B'.
Definition this_is_b' := 42.
End B'.
Fail Check this_is_b'. (* The module B' has not been Imported in A'. *)
Export B'.
Check this_is_b'. (* The module B' is now Imported in A'. *)
End A'.
Import A'.
Module B'.
End B'.
Export B'.
End A'.
Import A'.
Since B' was Exported in A', Importing A' also Imports B':
As this gives less control to the final user, Exporting modules should not
be done lightly.
A common usage is to write a library split in small library files and a
summary file Exporting all of them, so that requiring and importing it
makes all the library content available at once.
Another use case is when Importing a module (say about real numbers)
would only really make sense when another one (say about integers) is also
imported.
Other than that, Export behaves much like Import: it allows us to use
short names for constants, activates module features such as Hints,
Notations, etc.
One can also use selective import with Export, and locality attributes
behave the same.
Finally, it is possible to Require and Export a library file at the
same time.
For instance, the following command in Coq.Arith.Arith_base:
From Coq Require Export Arith.PeanoNat.
imports PeanoNat's content in Coq.Arith.Arith_base as well as in any
file which Requires and Imports (or Exports) Coq.Arith.Arith_base.
