Tutorial: Chaining Tactics
Main contributors
- Thomas Lamiaux
Summary
Table of content
- 1. Introduction to Chaining
- 2. Chaining Selectively on Subgoals
- 2.1 Basics
- 2.2 Ignoring Subgoals when Chaining
- 2.3 Chaining on a Range of Sugoals
- 3. Chaining is actually backtracking
- 4. Repeating Tactics and Chaining
Prerequisites
- No Prerequisites
- No Prerequisites
- Available by default with coq
In Coq, we prove theorems interactively, applying at each step a tactic
that transform the goal, and basically corresponds to applying a logical resonning.
Yet, in practice, it often happens that some of the primitive tactics are too low-level,
and that a higher-level resoning step we would like to do gets decomposed into
a sequence of tactics, and hence of interactive steps.
This is not very practical, as it hinders understanding when stepping through a proof.
It introduces extra interactive steps that we do not care about and can be tedious to run,
but also makes the logical structure of the proof harder to recognize and understand.
For instance, consider the second subgoal of the proof below.
Knowing a : A and b : B, we have to prove (A × B) + (A × C) + (A × D),
and hence would like to bring ourselves back to proving A × B.
While this corresponds to one simple logical step, it actually gets decomposed
into two tactics applied in a row left. left..
Goal A × (B + C + D) → A × B + A × C + A × D.
intros x. destruct x as [a x]. destruct x as [[b | c] | d].
- left. left. constructor.
-- assumption.
-- assumption.
- left. right. constructor.
-- assumption.
-- assumption.
- right. constructor.
-- assumption.
-- assumption.
Qed.
To recover the correspondence between the interactive steps and the logical steps
we have in mind, we would like to be able to chain tactics, so that in the example
left and right are excuted together, one after the other.
This is possible using the notation tac1 ; tac2 that is going to execute
the tactic tac1, and then tac2 on all the subgoals created by tac1.
In our case, it enables us to write left; left. rather than left. left.
to get one logical step:
- left; left. constructor.
-- assumption.
-- assumption.
- left; right. constructor.
-- assumption.
-- assumption.
-- assumption.
-- assumption.
Qed.
The real strength of chaining tactics appears when different subgoals are
created by a tactic, e.g tac1, that requires the same kind of proofs, e.g. tac2.
Indeed, in such cases, by chaining tactics tac1 to tac2, we can apply
tac2 on all subgoals created by tac1 at once, and do not have
to repeat tac2 for each subgoal.
In general, this enables to greatly factorise redundant code, while flattening
the code that is needing less sub-proofs / bullets.
Typically, in the example above, in all the cases created by constructor,
we want to apply assumption to conclude the proof.
We can hence share the code by writing constructor; assumption rather
than dealing with each subgoal independently, and in total to remove 6 subproofs.
This greatly simplifies the proof structure, while better reflecting the logical structure.
- left; left. constructor; assumption.
- left; right. constructor; assumption.
- right. constructor; assumption.
Qed.
2 Chaining Selectively on Subgoals
2.1 Basics
Goal (A → C) → (B → D) → A × B → C × D.
intros fAC fBD p. destruct p as [a b].
constructor.
- apply fAC. assumption.
- apply fBD. assumption.
Qed.
Yet, we would still like to be able to chain tactics together to factorise code and make it clear.
It is possible by using the notation tac; [tac1 | ... | tacn] that takes exactly
a tactic per subgoal created by tac, and apply taci on the i-th subgoal
This enables us to chain constructor with the apply by writing
constructor; [apply fAC | apply fBD] .
constructor; [apply fAC | apply fBD].
- assumption.
- assumption.
Qed.
This is particularly practical when the subgoals created require
a slightly different logical step, before resuming the same proof script.
In which case, we can use goal selection to do a differentiated reasoning
step before resuming regular chaining.
For instance, in the proof above, in both case, we conclude the proof
with assumption after applying fAC or fBC.
We can hence further chain [apply fAC | apply fBD] with assumption
to provide a significantly shorter proof:
constructor; [apply fAC | apply fBD] ; assumption.
Qed.
Goal (A → D) → (B → E) → (C → F) → A × B × C → D × E × F.
intros fAD fBE fCF p. destruct p as [[a b] c].
constructor.
- constructor.
-- apply fAD; assumption.
-- apply fBE; assumption.
- apply fCF; assumption.
Qed.
This is possible by either:
This enables to flatten the code removing the number of nested subgoals to prove,
while better reflecting the natural structure of the proof:
- 1. leaving the tactic spot empty
- 2. using the idtac tactic that does nothing
constructor; [constructor|].
Qed.
constructor; [constructor| idtac].
Qed.
If wished, it is then possible to further factorise the structure by
chaining the apply and assumption as before.
constructor; [constructor |]; [apply fAD | apply fBE | apply fCF]; assumption.
Qed.
However, as you can see it does not necessarily make the proof clearer.
Chaining is great but be careful not to overuse as it can create long and
unreadable proof, that no longer reflect logical steps.
This construction is also particularly practical to get rid of trivial subgoals
that are generated by a tactic. For instance, consider, the proof below where
a trivial subgoal is generated by constructor:
Goal (B → D) → (C → D ) → A × (B + C) → A × D.
intros fBD fCD p. destruct p as [a x].
constructor.
- assumption.
- destruct x; [apply fBD | apply fCD] ; assumption.
Qed.
Chaining with [assumption |] enables to get rid of the trivial goal,
making the proof flatter and letting us focus on the main goal:
constructor; [assumption |].
Qed.
Note, that it is also possible with the notation only n: tac that applies a
tactic only to the n-th goal.
constructor; only 1: assumption.
Qed.
Section Range.
Context (up : (A → D) → (B → D) → (C → D) → A + B + C → D).
Context (fA : A → D).
Context (fB : B → D).
Context (fC : C → D).
Goal ∀ (a : A), D.
intros a. apply up.
- assumption.
- assumption.
- assumption.
- left; left. assumption.
Qed.
Consequently, we would like to apply assumption on the first three subgoals to
get rid of the trivial goals before tackling the last one.
There are basically three facilities to do that, we can:
- 1. Use the notation only m-n,..., p-q: tac, that applies tac to the ranges of subgoals n-m, ..., and p-q
- 2. Use the .. notation to apply a tactic to all the subgoal until the next one specified like in [tac1 | tac2 .. | tack | tac n ].
- 3. Use the combinator try tac that tries to apply tac to all the subgoals, and it succeeds if no progress is possible
Goal ∀ (a : A), D.
intros a. apply up; only 1-3:assumption.
left; left; assumption.
Qed.
Goal ∀ (a : A), D.
intros a. apply up; [ assumption .. | ].
Qed.
Goal ∀ (a : A), D.
intros a. apply up; try assumption.
Qed.
(* try always succeeds *)
Goal ∀ (a : A), D.
intros a. apply up; try fail.
Abort.
Note that in this very particular case, we could have used first left; left
on the last goal then applied assumption everywhere, but it is not a good
idea in the facing case, we can hardly predict how difficult will be the last goal.
3 Chaining is actually backtracking
Qed.
Using constructor, we can replace left and right to get the same
proof script for the first and second goal, as:
- for the first goal, it will try left, continue with assumption and solve the goal
- for the second goal, it will try left, continue with assumption and fail, hence backtrack and try right, continue the proof and succded
- left; constructor; constructor; assumption.
Qed.
It can be a bit confusing at first, but once we got used to it, it is very
practical to write one proof script to deal with a bunch of barely different
subgoals.
For instance, we can then further simplify the proof by factorising the left and right
of the first and third subgoal. Then by using only 1-2: for the extra constructor,
of the first two subgoals, we can get one single proof script to solve all the goals:
all: constructor; only 1-2: constructor; constructor; assumption.
Qed.
Using the backtracking ability of ; to make the right choice out of
several possible choices is a simple but very powerful method that enables us
to write short but versatile proof scripts.
In the previous section, we have explained how to chain tactics linearly so
that they execute one after the other, on respectively created subgoals.
While this is already very practical, in some cases, we need a bit more
freedom like to be able to repeat tactics, or to try a set of tactics.
This is what we discuss in this section.
Consider the following example of section 1, that has ~25 interactive steps,
6 sub-proofs and is 10 lines long, even though it is a fairly simple proof.
-- assumption.
-- assumption.
-- assumption.
-- assumption.
-- assumption.
-- assumption.
Qed.
Chaining tactics linearly, we have managed to bring down the proofs to
only three interactive steps corresponding to the three logical steps of
the proof, and to only two lines.
Qed.
That is already nice, but the proof is still convoluted.
Not only do we have to repeat constructor three times, but we have to
think by ourselves when writing the proof that for the third case we only need
constructor once and not twice, and hence write only 1-2: constructor.
This, even though, the proof is conceptually simple: depending on our case
select the appropriate subtype to prove, e.g. A × C, and prove it
with constructor; assumption.
This is particular annoying as it does not scale very well.
Consider, this small variant with only two more types to distribute on.
The proof and its overhead then gets much greater, even though it is
conceptually as simple as before.
Goal A × (B + C + D + E + F) → A × B + A × C + A × D + A × E + A × F.
intros x. destruct x as [a x]. destruct x as [[[[b | c] | d] | e] | f].
all: constructor;
only 1-5: constructor;
only 1-4: constructor;
only 1-3: constructor;
assumption.
Qed.
Instead, we would like to be able to apply constructor as much as needed
using the backtracking to choose the good subtype to prove; then concludes
This is possible with the repeat tac combinator, that given a tactic
will apply it repeatedly until it can no longer be applied, or fails if it
can not be applied at all.
This enables us to refactor the proof by simply writing repeat constructor; assumption,
getting a proof that now fully correspond to the logical steps we wanted to take.
It further scales much better, as it works exactly the same for the variant
with two more types.
all: repeat constructor; assumption.
Qed.
Qed.
However, repeat can be a bit subtle, so be careful not to fall into this
two pitfalls:
- 1. repeat will stop if it succeeds, but it may not be what you expect
especially when backtracking is involved
all: repeat constructor. Fail all: assumption.
(* First case: proving A and B *)
- assumption.
- assumption.
(* Second case: proving A and B rather than A and C *)
- assumption.
- Fail assumption.
Abort.
- 2. repeat will apply a tactic as much as possible, it can be more than what you expect
Goal nat × (B + C + D) → nat × B + nat × C + nat × D.
intros x. destruct x as [n x]. destruct x as [b | c].
Show Proof.
Abort.
Such issues can be particularly annoying getting you stuck in an unprovable
goal, providing the wrong witness or wrongly unifying a metavariable,
impact the rest of the proof and getting you stuck latter on.
Once should hence be careful when it comes to using tactics combinator like repeat.
The repeat combinator also comes as a variant named do n tac that enables
to apply tac exactly n times, and if it cannot do it exactly n times
fails:
