Equations and Obligations
Summary
Equations is a plugin for that offers a powerful support for writing functions by dependent pattern matching. In this tutorial, we discuss how it interface with Program to help write programs using obligations.
In section 1, we recall the concept of obligation and how they interface with Equations. In Section 2, we discuss Equations' obligation solving tactic.
Table of content
  • 1. Equations and Obligations
    • 1.1 Obligations
    • 1.2 Solving obligations
  • 2. Equations' solving tactic
    • 2.1 Personalizing the tactic proving obligations
    • 2.2 What to do if goals are oversimplified
Prerequisites
Needed:
  • We assume basic knowledge of Coq, and of defining functions by recursion
  • We assume basic knowledge of the Equations plugin, e.g, as presented in the tutorial Equations: Basics
Not needed:
Installation:
  • Equations is available by default in the Coq Platform
  • Otherwise, it is available via opam under the name coq-equations
From Coq Require Import List.
Import ListNotations.
From Equations Require Import Equations.
Axiom to_fill : A, A.
Arguments to_fill {_}.
1.1 Obligations
In some cases, to define functions we may have to prove properties. There can be many reasons for that. Among others, the data structure under consideration may can include invariants that we must prove to be preserved when defining functions.
For instance, vectors of size n can be defined as lists of length n, that is, as a list l with a proof that length l = n.
Definition vec A n := { l : list A | length l = n }.
To define a function vec A n vec A m, one has to explain how the function acts on lists, and to prove that the resulting list is of size m providing the original one is of size n.
For instance, to define a concatenation function on vectors vapp : vec A n vec A m vec A (n + m), as done below, one has to:
  • specify that the concatenation of l and l' is app l l' and,
  • provide a proof term that length (ln ++ lm) = n + m, which is done below by the term eq_trans (length_app ln lm) (f_equal2 Nat.add Hn Hm).
Equations vapp {A n m} (v1 : vec A n) (v2 : vec A m) : vec A (n + m) :=
vapp (exist _ ln Hn) (exist _ lm Hm) :=
      (exist _ (app ln lm)
               (eq_trans (length_app ln lm) (f_equal2 Nat.add Hn Hm))).
Yet, in most cases, when defining a function, we do not want to write down the proofs directly as terms, as we did above. There are many reasons for that:
  • in practice, proof terms can be arbitrarily large and complex making it tedious if not impossible to write them down directly as terms
  • even if we could, this can easily make the function completely illegible
  • in case of changes, it is not possible to replay a term proof as we can replay a tactic script in order to adapt it, making functions harder to adapt
Therefore, we would much rather like to build our terms using the proof mode. This is exactly what Program and obligations enables us to do. At every point in a definition, it allows us to write down a wildcard _ instead of a term, it will then:
  • 1. create an obligation, intuitively a goal left to solve to complete the definition
  • 2. try to simplify the obligations and solve them using a tactic, in our case, using a tactic specific to Equations
  • 3. if there are any obligations left to solve, enable us to prove them using the proof mode and tactics using Next Obligation or Equations? that we discuss in section 1.2
For instance, we can define a function vapp n m : vec A n vec A m vec A (n+m) using a wildcard _ where a proof of length (app ln lm) = n + m is expected to prove it using tactics:
Equations vapp' {A n m} (v1 : vec A n) (v2 : vec A m) : vec A (n + m) :=
vapp' (exist _ ln Hn) (exist _ lm Hm) := exist _ (app ln lm) _.
Next Obligation.
  apply length_app.
Qed.
As you can see, this is very practical, however, you should be aware of three basic pitfalls:
1. As you may have noticed the goal to prove was not length (app ln lm) = n + m as expected, but length (app ln lm) = length ln + length lm. This is because Equations' custom solving tactic has already pre-simplified the goal for us. In can be an issue in some cases, and we discuss it in section 2.2.
2. Technically, you can use a wildcard _ for any term, even for one that is relevant (i.e. not a proof) to the definition and computation like app ln lm. Yet, it is generally a bad idea as automation could then infer something random that by concidence happens to match the expected type.
3. Be aware that a definition is not defined until all its associated obligations have been solved. Trying to refer to it before that, we consequently trigger the error that the defintion was not found. For instance, consider the unfinished definition of vmap with a wildcar _
Equations vmap {A B n} (f : A B) (v : vec A n) : vec B n :=
vmap f (exist _ ln Hn) := exist _ (map f ln) _ .
Fail Definition vmap_comp {A B C n} (g : B C) (f : A B) (v : vec A n)
    : vmap g (vmap f n v) = vmap (fun xg (f x)) v.
Obligations are not well displayed by all IDE. If it the case, you can always print them using Obligations of name_obligations. For instance, for vmap:
Obligations of vmap_obligations.
There are two different methods to solve the remaining obligations.
You can solve the obligations one by one using the command Next Obligations. Doing so for vmap display the goal length (map f ln) = length ln, which we can then solve using tactics.
Next Obligation.
  apply length_map.
Qed.
Using Next Obligation has the advantage that once an obligation has been solved, Program retries automatically to prove the remaining obligations. It can be practical when proofs are simple but requires for a variable to be solved first to be able to proceed.
Note, that it can be useful to add Fail Next Obligation once all obligations have been solved. This way, if a change somewhere now leaves an obligation unsolved, we can easily track down the issue to the culprit definition.
Alternatively, it is possible to use the keyword Equations? to automatically unshelve all obligations, that is enter the proof mode and create a goal for each of the obligations remaining.
For an example, we can redefine vmap using it:
Equations? vmap' {A B n} (f : A B) (v : vec A n) : vec B n :=
vmap' f (exist _ ln Hn) := exist _ (map f ln) _ .
Proof.
  apply length_map.
Defined.
Though, note that Equations? triggers a warning when used on a definition that leaves no obligations unsolved. It is because for technical reasons, Equations? cannot check if there is at least one obligation left to solve before opening the proof mode. Hence, when there is no obligation proof mode is opened for nothing, and has to be closed by hand using Qed (for proof irrelevant content) as it can be seen below. As it is easy to forget, a warning is raised.
Equations? vnil {A} : vec A 0 :=
vnil := exist _ nil eq_refl.
Defined.
As mentioned, Equations automatically tries to solve obligations. It does so using a custom strategy basically simplifying the goals and running a solver. It can be viewed with the following command:
Show Obligation Tactic.
When working, it is common to be dealing with a particular class of functions that shares a common theory, e.g, they involve basic arithmetic. This theory cannot not be guessed by the basic automation tactic, so one may want a personalized tactic to handle a particular theory.
This can be done using the command #[local] Obligation Tactic := tac that locally changes the tactic solving obligation to tac.
For example, consider a gcd function defined by well-founded recursion. There are two obligations left to prove corresponding to proofs that the recursive call are indeed performed on smaller instance. Each of them corresponds to basic reasoning about arithmetics, and can be solved with the solver lia.
Require Import Arith Lia.
Equations? gcd (x y : nat) : nat by wf (x + y) lt :=
gcd 0 x := x ;
gcd x 0 := x ;
gcd x y with gt_eq_gt_dec x y := {
  | inleft (left _) := gcd x (y - x) ;
  | inleft (right refl) := x ;
  | inright _ := gcd (x - y) y }.
Proof.
  lia. lia.
Abort.
Therefore, we would like to locally change the tactic solving the obligations to take into account arithmetic, and try the lia tactic. We do so by simply trying it after the current solving tactic, i.e. the one displayed by Show Obligation Tactic. As we can see by running again Show Obligation Tactic, it has indeed been added, and gcd is now accepted directly.
          simpl in *;
          Tactics.program_simplify;
          CoreTactics.equations_simpl;
          try Tactics.program_solve_wf;
          try lia.
Equations gcd (x y : nat) : nat by wf (x + y) lt :=
gcd 0 x := x ;
gcd x 0 := x ;
In some cases, it can happen that Equations' solving tactic is too abrut and oversimplies goals, or mis-specialised and ends up getting us stuck. The automation can also become slow, and one might want to diagnose this. In any of these cases, it can be useful to set the solving tactic locally to the identity. That way, the obligations one gets is the raw ones generated by Equations without preprocessing, which can then be "manually" explored.
In this case, a useful trick is to use an attribute to set the obligation tactic to idtac only for the definition at hand, using the scheme #[tactic="idtac"] Equations? name ....
Unfortunately, at the moment we do not have a simple enough minimal working example. If you have one, do not hesitate to create a PR.
