Tutorial Equations : Basic Definitions and Reasoning with Equations
Summary
Equations is a plugin for Coq that offers a powerful support for writing functions by dependent pattern matching, possibly using well-founded recursion and obligations. To help reason on programs, Equations also comes with its own set of tactics, and can automatically derive properties like no-confusion properties or subterm relations.Table of content
- 1. Basic definitions and reasoning
- 1.1 Defining functions by dependent pattern matching
- 1.2 Reasoning with Equations
- 1.2.1 Simplifying goals with autorewrite
- 1.2.2 Proving properties by functional elimination with funelim
- 1.2.3 Discharging trivial goals with simp
- 1.2.4 Extending autorewrite and simp
- 2. With clauses
- 3. Where clauses
Prerequisites
- We assume known basic knowledge of Coq, of and defining functions by recursion
- Equations is available by default in the Coq Platform
- Otherwise, it is available via opam under the name coq-equations
Inductive list A : Type :=
| nil : list A
| cons : A → list A → list A.
Arguments nil {_}.
Arguments cons {_} _ _.
To write a function f : list A → B on lists or another a basic
inductive type, it suffices to write:
For instance, we can define the function tail, length and app by:
- Equations at the beginning of you function rather than Fixpoint
- For each constructor cst x1 ... xn like cons a l, specify how f computes on it by writing f (cst x1 ... xn) := t where t may contain f recursively.
- Separate the different cases by semi-colon ";"
- As usual finish you definition by a dot "."
Equations tail {A} (l : list A) : list A :=
tail nil := nil;
tail (cons a l) := l.
Equations length {A} (l : list A) : nat :=
length nil := 0;
length (cons a l) := S (length l).
Equations app {A} (l l' : list A) : list A :=
app nil l' := l';
app (cons a l) l' := cons a (app l l').
Infix "++" := app (right associativity, at level 60).
Equations is compatible with usual facilities provided by Coq to write
terms:
- It is compatible with implicit arguments that as usual do not need to be written provided it can be inferred. For instance, above, we wrote app nil l' rather than app (nil A) l' as A was declared as an implicit argument of nil.
- We can use underscores "_" for terms that we do not use, terms that Coq can infer on its own, but also to describe what to do in all remaining cases of our pattern matching. As list only has two constructors, it is not very useful here, but we can still see it works by defining a constant function:
- We can use notations both in the pattern matching (on the left-hand side of :=) or in the bodies of the function (on the right-hand side of :=). This provides an easy and very visual way to define functions. For instance, with the usual notations for lists, we can redefine length and app as:
Notation "[]" := nil.
Notation "[ x ]" := (cons x nil).
Notation "x :: l" := (cons x l).
Equations length' {A} (l : list A) : nat :=
length' [] := 0;
length' (a::l) := S (length' l).
Equations app' {A} (l l' : list A) : list A :=
app' [] l' := l';
app' (a::l) l' := a :: (app' l l').
For the users that would prefer it, there is also an alternative syntax
closer to the the one provided by the Fixpoint command and Coq's native pattern-matching.
With this syntax, we have to start each clause with "|" and separate the
different patterns in a clause by ",", but we no longer have to repeat
the name of the functions nor to put parenthesis or finish a line by ";".
With this syntax, we can rewrite length and app as:
Equations length'' {A} (l : list A) : nat :=
| [] := 0
| (a::l) := S (length'' l).
Equations app'' {A} (l l' : list A) : list A :=
| [] , l' := l'
| (a::l), l' := a :: (app'' l l').
In this tutorial, we will keep to the first syntax but both are can be
used interchangeably.
Equations enables us to pattern match on several different
variables at the same time, for instance, to define a function nth_option
getting the nth-element of a list and returning None otherwise.
Equations nth_option {A} (n : nat) (l : list A) : option A :=
nth_option 0 [] := None ;
nth_option 0 (a::l) := Some a ;
nth_option (S n) [] := None ;
nth_option (S n) (a::l) := nth_option n l.
However, be careful that as for definitions using Fixpoint, the order
of matching matters: it produces terms that are pointwise propositionally
equal but with different computation rules.
For instance, if we pattern match on l first, we get a function
nth_option' that is equal to nth_option but computes differently
as it can been seen below:
Equations nth_option' {A} (l : list A) (n : nat) : option A :=
nth_option' [] _ := None;
nth_option' (a::l) 0 := Some a;
nth_option' (a::l) (S n) := nth_option' l n.
Goal ∀ {A} (a:A) n, nth_option n (nil (A := A)) = nth_option' (nil (A := A)) n.
Proof.
(* Here autorewrite with f is a simplification tactic of Equations (c.f. 1.1.2).
As we can see, nth_option' reduces on [] to None but not nth_option. *)
intros.
autorewrite with nth_option.
autorewrite with nth_option'.
(* We need to further destruct n to simplify *)
destruct n; reflexivity.
Abort.
Equations also supports nested pattern matching.
For instance, we can define a function swapping lists of pairs
by matching pairs at the same as we match the list.
Equations swap_list_pair {A B} (l : list (A × B)) : list (B × A) :=
swap_list_pair [] := [];
swap_list_pair ((a , b)::l) := (b,a)::(swap_list_pair l).
As exercises, you can try to define:
- A function map f l that applies f pointwise, on [a1, ... ,an] it returns [f a1, ... , f an]
- A function head_option that returns the head of a list and None otherwise
- A function fold_right f b l that on a list [a1, ..., an] returns the element f a1 (... (f an b))
Equations map {A B} (f : A → B) (l : list A) : list B :=
map f _ := to_fill.
Equations head_option {A} (l : list A) : option A :=
head_option _ := to_fill.
Equations fold_right {A B} (f : A → B → B) (b : B) (l : list A) : B :=
fold_right f b _ := to_fill.
(* You can uncomment the following tests to try your functions *)
Succeed Example testing : map (Nat.add 1) (1::2::3::4::) = (2::3::4::5::)
:= eq_refl.
Succeed Example testing : @head_option nat = None := eq_refl.
Succeed Example testing : head_option (1::2::3::) = Some 1 := eq_refl.
Succeed Example testing : fold_right Nat.mul 1 (1::2::3::4::) = 24 := eq_refl.
Lemma nil_app {A} (l : list A) : [] ++ l = l.
Proof.
(* unfold fails, and cbn has no effect *)
Fail unfold "++". Fail progress cbn.
(* But reflexivity works *)
reflexivity.
Qed.
If one really wishes to recover unfolding, it is possible though on a case by case
basis using the option Global Transparent f as shown below.
It is also possible to set this option globally with Set Equations
Transparent, but it is not recommended to casual users.
To recover simplification by simpl and cbn, one can additionally
use the command Arguments function_name !_ /. .
It will simplify the function as soon as it is applied to at least one
argument that is a constructor.
Equations f4 (n : nat) : nat :=
f4 _ := 4.
Global Transparent f4.
Goal f4 3 = 4.
Proof.
(* f4 can now be unfolded *)
unfold f4.
Abort.
Goal f4 3 = 4.
Proof.
(* Yet, it still cannot be simplify by cbn *)
Fail progress cbn.
(* Arguments enables to recover simplification *)
Arguments f4 !_ /. cbn.
Abort.
Rather than using cbn or simpl, for each function f, Equations
internally proves an equality for each case of the pattern matching
defining f, and declares it in a hint database named f.
For instance, for app, it proves and declares app [] l' = l' and
app (a::l) l' = a :: (app l l').
The equalities are named using the scheme "function_name_equation_n", and you
can check them out using the command Print Rewrite HintDb function_name:
Print Rewrite HintDb app.
It is then possible to simplify by the equations associated
to functions f1 ... fn using the tactic autorewrite with f1 ... fn.
Note, it is also possible to simplify in hypotheses using
autorewrite with f1 ... fn in H.
As an example, let us prove app_nil l : l ++ [] = l.
As app is defined by pattern match on l, we prove the result by
induction on l, and use autorewrite with app to simplify the goals.
Lemma app_nil {A} (l : list A) : l ++ [] = l.
Proof.
intros; induction l. all: autorewrite with app.
- reflexivity.
- rewrite IHl. reflexivity.
Qed.
Lemma app_assoc {A} (l1 l2 l3 : list A) : (l1 ++ l2) ++ l3 = l1 ++ (l2 ++ l3).
Proof.
induction l1. all: autorewrite with app.
- reflexivity.
- rewrite IHl1. reflexivity.
Qed.
This provide a fine control of unfolding as it simplifies only by the defining
equations, and will not unfold anything else, while leaving the possibility to
rewrite directly by a specific equation.
In particular, compared to cbn it will never unfold unwanted terms, like
proofs terms that would be part of the definition, for instance, when defining
proof carrying function or functions by well-fouded recursion.
In the examples above app_nil and app_assoc, we mimicked the pattern
used in the definition of app by induction l.
While it works on simple examples, it quickly gets more complicated.
For instance, consider the barely more elaborate example proving
that both definition of nth_option are equal.
We have to be careful to first revert n in order to generalise the
induction hypotheses and get something strong enough when inducting on l,
and we then need to destruct n.
Lemma nth_eq {A} (l : list A) (n : nat) : nth_option n l = nth_option' l n.
Proof.
revert n; induction l; intro n; destruct n.
all : autorewrite with nth_option nth_option'.
- reflexivity.
- reflexivity.
- reflexivity.
- apply IHl.
Abort.
On real life examples, reproducing the patterns by hand with the good
induction hypotheses can quickly get tedious, if not challenging.
Inductive types and patterns can quickly get complicated.
Moreover, functions may actually not even be defined following the
structure of an inductive type making it hard to reproduce at all.
For a simple example, consider the function half and mod2 that
are defined recursively on S (S n) rather than on S n:
Equations half (n : nat) : nat :=
half 0 := 0 ;
half 1 := 0 ;
half (S (S n)) := S (half n).
Equations mod2 (n : nat) : nat :=
mod2 0 := 0;
mod2 1 := 1;
mod2 (S (S n)) := mod2 n.
If we try to naively prove a property P about half or mod2
by repeated induction on n, we actually quickly get stuck.
Indeed, as we can see below, in the recursive case we have to prove
P (S (S n)) knowing P (S n) and that P n → P (S n).
Yet, in general to be able to reason about half or mod2,
we actually need to know that P n hold to prove P (S (S n)).
Goal ∀ (P : nat → Prop) (H0 : P 0) (H1 : P 1) (n : nat), P n.
Proof.
induction n. 1: exact H0.
induction n. 1: exact H1.
(* We are stuck *)
Abort.
This issue arises more generally as soon as we start defining functions using
more advanced notions of matching like with and where clauses (c.f. 2. and 3.),
or when defining functions using well-founded recursion.
Consequently, to help us reason about complex functions, for each definition,
Equations derives a functional induction principle.
This is an induction principle that follows the structure of the
function, including nested pattern-matching, with and where clauses,
correct induction hypotheses and generalisation as in the above example.
This principle is named using the scheme "function_name_elim".
For instance, to prove a goal P depending on n and half n,
half_elim asserts that it suffices to prove
- P 0 (half 0)
- P 1 (half 1)
- and that P n (half n) → P (S (S n)) (half (S (S n)))
Moreover, Equations comes with a powerful tactic funelim that
applies the functional induction principle and simplifies the associated definition.
To use it, it suffices to write funelim (function_name a1 ... an)
where a1 ... an are the arguments you want to do your induction on.
As an example, let us prove nth_eq and half_mod2 for
which we can already see the advantages over trying to reproduce the
pattern matching by hand:
Proof.
funelim (nth_option n l).
all: autorewrite with nth_option'.
- reflexivity.
- reflexivity.
- reflexivity.
- apply H.
Abort.
(* Doing induction naively to reproduce a pattern can get you stuck *)
Definition half_mod2 (n : nat) : n = half n + half n + mod2 n.
Proof.
induction n. 1: reflexivity.
(* We simplify the goal *)
autorewrite with half mod2.
rewrite PeanoNat.Nat.add_succ_r. cbn.
f_equal. f_equal.
(* We then get stuck as we have the wrong hypotheses *)
Abort.
(* Wheras funelim does it automatically for you *)
Proof.
funelim (half n). 1-2: reflexivity.
f_equal. f_equal.
(* We now have the good recursion hypotheses *)
assumption.
Qed.
Definition nth_eq {A} (l : list A) (n : nat) : nth_option n l = nth_option' l n.
Proof.
funelim (nth_option n l); simp nth_option nth_option'.
all : reflexivity.
Abort.
As you can see, by default simp does not try to prove goals that hold
by definition, like None = None.
If you wish for simp to do so, or for simp to try any other tactic,
you need to add it as a hint to one of the hint databse simp used by simp.
In particular, you can extend simp to to prove definitional equality using
the following command.
#[local] Hint Resolve eq_refl : simp.
Proof.
Qed.
Equations rev {A} (l : list A) : list A :=
rev [] := [];
rev (a::l) := rev l ++ [a].
Equations rev_acc {A} (l : list A) (acc : list A) : list A :=
rev_acc nil acc := acc;
rev_acc (cons a v) acc := rev_acc v (a :: acc).
Lemma rev_rev_acc {A} (l l' : list A) : rev_acc l l' = rev l ++ l'.
Proof.
funelim (rev l). all: autorewrite with rev rev_acc app.
- reflexivity.
(* We have to rewrite by app_assoc by hand *)
- rewrite app_assoc. apply H.
Abort.
(* Adding app_nil and app_assoc the database associated to app *)
#[local] Hint Rewrite @app_nil @app_assoc : app.
(* We can check it has indeed been added *)
(* autorewrite with app can now use app_assoc *)
Goal ∀ {A} (l1 l2 l3 l4 : list A),
((l1 ++ l2) ++ l3) ++ l4 = l1 ++ (l2 ++ (l3 ++ l4)).
Proof.
intros. autorewrite with app. reflexivity.
Qed.
Lemma rev_eq {A} (l l' : list A) : rev_acc l l' = rev l ++ l'.
Proof.
funelim (rev l); autorewrite with rev rev_acc app.
- reflexivity.
(* There is no more need to call app_assoc by hand in proofs *)
- apply H.
Abort.
It actually enables to greatly automate proofs using simp
Proof.
funelim (rev l); simp rev rev_acc app.
Qed.
Proof.
Qed.
Lemma app_length {A} (l l' : list A) : length (l ++ l') = length l + length l'.
Proof.
Admitted.
(* You will need to use the lemma le_S_n *)
Lemma nth_overflow {A} (n : nat) (l : list A) : length l ≤ n → nth_option n l = None.
Proof.
Admitted.
(* You will need to use the lemma PeanoNat.lt_S_n
HINT : funelim must be applied to the parameters you want to do the induction on.
Here, it is n and l, and not n and l++l'.
Lemma app_nth1 {A} (n : nat) (l l' : list A) :
n < length l → nth_option n (l++l') = nth_option n l.
Proof.
(* intro H; funelim (nth_option n l); simp nth_option app.
3: { apply H. apply PeanoNat.lt_S_n. } *)
Admitted.
(* You will need the lemma le_S_n.
Here, it is n and l, and not (n - length l) and l'. *)
Lemma app_nth2 {A} (n : nat) (l l' : list A) :
length l ≤ n → nth_option n (l++l') = nth_option (n-length l) l'.
Proof.
Admitted.
Lemma distr_rev {A} (l l' : list A) : rev (l ++ l') = rev l' ++ rev l.
Proof.
Admitted.
Proof.
Admitted.
Proof.
Admitted.
Proof.
Admitted.
Proof.
Admitted.
Proof.
Admitted.
2. With clauses
f (cxt x1 ... xn) with b ⇒ {
(cxt x1 ... xn) p1 := ... ;
(cxt x1 ... xn) pk := ...
Equations filter {A} (l : list A) (p : A → bool) : list A :=
filter nil p := nil ;
filter (cons a l) p with p a ⇒ {
filter (cons a l) p true := a :: filter l p ;
filter (cons a l) p false := filter l p }.
This syntax is a bit heavy. To avoid repeating the full clause
filter (cons a l) p and to focus on the with pattern, we can use the
Fixpoint like syntax in the with clause discussed in section 1.1.
This enables to rewrite the with clause of the function filter
much more concisely:
Equations filter' {A} (l : list A) (p : A → bool) : list A :=
filter' [] p ⇒ [];
filter' (a :: l) p with p a ⇒ {
| true ⇒ a :: filter' l p
| false ⇒ filter' l p
To show that filter is well-behaved, we can define a predicate In and
check that if an element is in the list and verifies the predicate,
then it is in the filtered list.
For function defined using with clauses, funelim does the usual
disjunction of cases for us, and additionally destructs the pattern
associated to the with clause and remembers it.
In the case of filter, it means additionally destructing p a and
remembering whether p a = true or p a = false.
For regular patterns, simplifying filter behaves as usual when using funelim:
Lemma filter_In {A} (x : A) (l : list A) (p : A → bool)
: In x (filter l p) ↔ In x l ∧ p x = true.
Proof.
funelim (filter l p); simp filter In.
- intuition congruence.
- rewrite H. intuition congruence.
Qed.
However, simplifying with clauses can make subclauses appear corresponding
to the different branches of the with clause.
For filter', in the p a = true case, a filter_clause_1 appears, and
similarly in the false case.
This is due to Equations' internal mechanics.
To simplify the goal further, it suffices to rewrite p a by its value
in the branch, and to simplify filter again.
Lemma filter_filter' {A} (l : list A) (p : A → bool)
: filter l p = filter' l p.
Proof.
funelim (filter l p); simp filter'.
- rewrite Heq. cbn. reflexivity.
Qed.
With clauses can also be useful to inspect a recursive call.
For instance, with clause enables us to write a particularly concise
definition of the unzip function:
Equations unzip {A B} (l : list (A × B)) : list A × list B :=
unzip [] := ([],[]);
unzip ((a,b)::l) with unzip l ⇒ {
| (la,lb) ⇒ (a::la, b::lb)
Finally, with clauses can be used to discard impossible branches.
For instance, rather than returning an option type, we can define a
head function by requiring the input to be different than the
empty list.
In the nil case, we can then destruct pf eq_refl : False which
has no constructors to define our function.
Equations head {A} (l : list A) (pf : l ≠ nil) : A :=
head [] pf with (pf eq_refl) := { };
head (a::l) _ := a.
As exercices, you can try to:
- Prove that both head functions are equal up to Some
- Prove that a filtered list has a smaller length than the original one
- Define a function find_dictionary that given a key and an equality test, returns the first element associated to the key and None otherwise
Definition head_head {A} (l : list A) (pf : l ≠ nil)
: Some (head l pf) = head_option l.
Proof.
Admitted.
(* You may need the lemma le_n_S and PeanoNat.Nat.le_le_succ_r *)
Definition filter_length {A} (l : list A) (p : A → bool)
: length (filter l p) ≤ length l.
Proof.
Admitted.
Equations find_dictionary {A B} (eq : A → A → bool) (key : A)
(l : list (A × B)) : option B :=
find_dictionary eq key [] := to_fill;
find_dictionary eq key _ with @to_fill bool ⇒ {
| _ := to_fill
(* Definition example_dictionnary :=
(3,true::true::) :: (0,) :: (2,true::false::) :: (1,true::) :: .
find_dictionary Nat.eqb 2 example_dictionnary = Some (true::false::) := eq_refl.
find_dictionary Nat.eqb 4 example_dictionnary = None := eq_refl. *)
3. Where Clauses
Equations rev_acc' {A} (l : list A) : list A :=
rev_acc' l := rev_acc_aux l []
where rev_acc_aux : (list A → list A → list A) :=
rev_acc_aux [] acc := acc;
rev_acc_aux (a::tl) acc := rev_acc_aux tl (a::acc).
Reasoning on functions defined using where clauses is a bit more tricky as we
need a predicate for the first function, and for the auxiliary function.
The first one is usually call the wrapper and the other the worker.
While the first one is obvious as it is the property we are trying to prove,
Coq cannot invent the second one on its own.
Consequently, we cannot simply apply funelim. We need to apply ourself
the recurrence principle rev_acc_elim automatically generated by Equations
for rev_acc that is behind funelim.
Lemma rev_acc_rev {A} (l : list A) : rev_acc' l = rev l.
Proof.
unshelve eapply rev_acc'_elim.
1: exact (fun A _ l acc aux_res ⇒ aux_res = rev l ++ acc).
all: cbn; intros.
(* Functional elimination provides us with the worker property initialised
as in the definition of the main function *)
- rewrite app_nil in H. assumption.
(* For the worker proofs themselves, we use standard reasoning. *)
- reflexivity.
- simp rev. rewrite H. rewrite app_assoc. reflexivity.
Abort.
This proof can actually be mostly automated thanks to Equations.
- We can automatically deal with app_nil and app_assoc by adding them to simplification done by autorewrite as done in 1.1.2
- We can combine that with a proof search using simp
