Tutorial Equations : Dealing with indexed inductive types
Main contributors
- Thomas Lamiaux
- Matthieu Sozeau
Summary:
Table of content
- 1. Basic Reasoning on Indexed Inductive Types
- 2. Advanced Dependent Pattern Matching
- 2.1 Discarding Automatically Impossible Cases
- 2.2 The No-Confusion Properties
- 2.3 The Tactic Depelim
- 3. Unifying Indices and Inaccessible Patterns
Prerequisites:
- We assume basic knowledge of Coq, of and defining functions by recursion
- We assume basic knowledge of the plugin Equations, e.g, as presented in the tutorial Equations : Basics
- We discuss here indexed inductives but we recall the concept so previous knowledge about them is not needed
- Equations is available by default in the Coq Platform
- Otherwise, it is available via opam under the name coq-equations
From Equations Require Import Equations.
Inductive vec A : nat → Type :=
| vnil : vec A 0
| vcons : A → ∀ (n : nat), vec A n → vec A (S n).
Arguments vnil {_}.
Arguments vcons {_} _ _ _.
The difference between a parameter and an index is that a parameter is
constant accros all the return types of the constructors, whereas an index
changes in at least one of the return types.
For instance, in the definition of vectors the type A is a parameter
as it is constant across all the return types: vec A 0 and vec A (S n).
However, n:nat is an index as it is not constant in the returns types:
in the return type of vnil it is fixed to 0, and in the return type of vcons it is S n.
Indices always appear after the : in an inductive type declaration.
Reasoning about indexed inductive types like vectors is a bit more
involved than for basic inductive types like lists as the indices can
matter.
Noticeably pattern matching on constructors of indexed inductive types
like vec A n may particularise the indices.
For instance, matching a vector v : vec A n to vnil forces the
value n to be 0 while for vcons if forces n to be of the form
S m for some integer m.
Consequently, when writing a function on an indexed inductive type,
pattern-matching on the inductive type has an effect on other arguments
of the function, specializing them.
For instance, consider the definition of vmap and vapp :
Equations vmap {A B} (f : A → B) (n : nat) (v : vec A n) : vec B n :=
vmap f _ vnil := vnil ;
vmap f _ (vcons a n v) := vcons (f a) n (vmap f n v).
Print vmap.
Equations vapp {A} (n : nat) (v : vec A n) (m : nat) (v' : vec A m) : vec A (n+m) :=
vapp 0 vnil m v' := v';
vapp (S n') (vcons a n' v) m v' := vcons a (n'+m) (vapp n' v m v').
(* Here the only two possibly well-typed patterns when considering the vnil and vcons
constructors are respectively with n = 0 and n = S n' for some fresh n' variable. *)
Reasoning on indexed inductive is not very different from reasoning
on regular inductive types except that we have to account for indices,
which can in some cases cause some overheads.
For basic properties as below, it makes no differences:
Definition vmap_comp {A B C} (f : A → B) (g : B → C) (n : nat) (v : vec A n) :
vmap g n (vmap f n v) = vmap (fun a ⇒ g (f a)) n v.
Proof.
funelim (vmap f n v); simp vmap.
- reflexivity.
- f_equal. apply H.
Qed.
Lemma vmap_cong {A B n} (f f': A → B) (v : vec A n) (Heq : ∀ (a:A), f a = f' a)
: vmap f n v = vmap f' n v.
Proof.
- reflexivity.
- now rewrite Heq, (H f').
Qed.
However, it can make some differences when operations on indices are
involved as indices are relevant for simplification.
For instance, if we try to prove that vmap respects vapp as below,
in the vcons case simplification fails to simplify vmap f (S n + m) ....
The reason is that the simplification rule associated to vcons is
vmap f (S n) (vcons a n v) = vcons (f a) n (vmap f n v).
Hence, simp can not simplify vmap until S n + m has been
simplified to S (n+m) using cbn.
It then behaves as usual.
Definition vmap_vapp {A B} (n m : nat) (f : A → B) (v : vec A n) (v' : vec A m) :
vmap f (n+m) (vapp n v m v') = vapp n (vmap f n v) m (vmap f m v').
Proof.
funelim (vmap f n v); simp vapp.
- reflexivity.
- (* Here we can see simp fails to simplify vmap f (S n + m) ... as
S n + m is not of the form S x for some x : nat. *)
simp vmap.
(* We need to first simplify + using cbn : *)
cbn.
(* We can now simplify *)
simp vmap vapp. now rewrite H.
Qed.
This is not a limitation of Equations itself. It is due to how the
rewrite tactic behind simp unifies terms.
In practice, indices are mostly inferable, so it is usually possible to
make them implicit.
It has the advantage to make the code much more concise.
For instance, for vec, it enables to write much shorter definitions
of vmap and vapp:
Arguments vcons {_} _ {_} _.
Equations vmap' {A B n} (f : A → B) (v : vec A n) : vec B n :=
vmap' f vnil := vnil ;
vmap' f (vcons a v) := vcons (f a) (vmap' f v).
Equations vapp' {A n m} (v : vec A n) (v' : vec A m) : vec A (n+m) :=
vapp' vnil v' := v';
vapp' (vcons a v) v' := vcons a (vapp' v v').
Setting indices to be implicit also makes them implicit in proofs.
Doing so is not an issue even in the case of vmap_vapp where
we need to simplify indices to reduce.
If we think a term should have been reduced but hasn't been because of
indices, we can always make them temporally explicit to check.
We can do so by defining an alias for the functions using the tactic
set (name_function_ex := @(name_function _ _ _)) with an underscore
for the arguments we do not want to make explicit.
After inspecting the goal, you can just erase the tactic or unfold
the notations.
As an example, let's reprove vmap_vapp :
Definition vmap_vapp' {A B n m }(f : A → B) (v : vec A n) (v' : vec A m) :
vmap' f (vapp' v v') = vapp' (vmap' f v) (vmap' f v').
Proof.
funelim (vmap' f v).
- reflexivity.
- simp vapp'.
(* If we think vmap' f (vcons a ...) should have been simplified,
we can set an alias to check if the index is of the form S x *)
set (vmap'_ex := @vmap' _ _).
(* After inspecting the goal, you can just erase the tactic
or unfold the alias *)
cbn. unfold vmap'_ex.
(* It is now possible to simplify *)
simp vmap' vapp'. f_equal. apply H.
Abort.
An alternative is to change the way rewrite looks for matching subterms
in the goal, using the keyed unification strategy. With this setting, rewrite (e : t = u)
looks for a syntactic match for the head of t in the goal but allows full
conversion between arguments of t and the arguments of the matched application
in the goal. This makes simp work up-to conversion of the indices.
We can then directly call congruence to solve the induction case.
#[local] Set Keyed Unification.
Definition vmap_vapp_simp {A B n m }(f : A → B) (v : vec A n) (v' : vec A m) :
funelim (vmap' f v); simp vmap' vapp'.
- reflexivity.
- congruence.
Qed.
Similarly, we can give a very short definition of a function computing
the diagonal of a square matrix of size n × n represented as a
vector of vector v : vector (vector A n) n).
On the empty matrix it returns the empty list.
On a matrix (vcons (vcons a v) v') of size (S n) x (S n) representing
| a | v |
| v' |
it returns a added to the diagonal of vmap vtail v', that is
v' where the first column has been forgotten.
Note, that in this case, pattern matching on n needs to be added to help
Coq see it is a strictly decreasing structurally recursive definition on the index.
vmap vtail v' can otherwise not be recognized as a syntactic subterm of v'.
An alternative definition using well founded-recursion is presented below.
| a | v |
| v' |
Equations diag {A n} (v : vec (vec A n) n) : vec A n :=
diag (n:=O) vnil := vnil ;
diag (n:=S _) (vcons (vcons a v) v') := vcons a (diag (vmap vtail _ v')).
Thanks to funelim, reasoning for this kind of programs is as usual
to the difference that, as for function definitions, we only need to
deal with the cases that are possible:
Arguments vmap {_ _} _ {_} _.
Definition vmap_diag {A B n} (f : A → B) (v : vec (vec A n) n) :
vmap f (diag v) = diag (vmap (fun v' ⇒ vmap f v') v).
Proof.
(* We start by induction, simplify and use the induction hypothesis *)
funelim (diag v); simp vmap diag. 1: easy. rewrite H. f_equal.
(* We simplify the goal by collapsing the different vmap using vmap_comp,
and notice the proof boils down to commutativity of vtail and vmap *)
rewrite ! vmap_comp. f_equal. apply vmap_cong.
(* There is left to prove by function elimination on vtail or vmap *)
intro v2. clear -v2. funelim (vtail v2). simp vmap vtail. reflexivity.
Qed.
You may have noticed that we have derived the no-confusion property for nat
after defining tail and diag, even though it is supposed to be necessary.
This is because it is already defined for nat by default, so there was
actually no need to do derive it in this particular case.
nat is a very simple inductive type.
In the general case, for indexed inductive types, there are two kind of no-confusion
properties that can be derived by Equations:
- The NoConfusion property that enables to distinguish object with different indices. It takes as argument objects in the total space {n : nat & vec A n} which is generated once and for all with `Derive Signature for vec`. It enables to solve general equations between objects in potentially different instances of the inductive family:
- The NoConfusionHom property that enables to distinguish objects with the same indices (i.e., in the same instance of the inductive family), which is useful for simplifying homogeneous equations:
Note that you can also derive all of them at once using Derive Signature NoConfusion NoConfusionHom for vec.
While the NoConfusionHom property is derivable for many indexed inductive types,
it is not the case that is derivable for all indexed inductive types.
It is derivable only when equality of constructors can be reduced to equality
of the non-forced constructor arguments. A forced argument of a constructor
is a constructor argument (say of variable name x) that appears in a pattern
position in an index of the constructor's type conclusion. Patterns are generated
from variables and constructor applications in this case.
For example on vectors, this corresponds to the fact that for vcons a n v : vec A (S n),
n appears in a pattern position in S n. Intuitively, the value of the *forced*
constructor argument n can be inverted from the type vec A (S n).
NoConfusionHom for vcons proves that
vcons a n v = vcons a' n v' :> vec A (S n) ↔ a = a' ∧ v = v' :> vec A n,
i.e. we can eliminate the trivial n = n equality on the forced argument n.
This ultimately relies on the UIP property for nat which shows that ∀ e : n = n, e = eq_refl n.
If it is not possible to derive it, then Equations may need the indices to
satisfy Uniqueness of Identity Proofs, asserting that all equality proofs are
equal, i.e. UIP : ∀ (A : Type) (a b : A) (p q : a = b), p = q, to be able to
elaborate the definition to a Coq term.
UIP holds for types like nat where equality is decidable, but it is not provable
for all types. In particular, it is not provable for Type itself.
It can be assumed as an axiom, but be mindful that while this is consistent with Coq's
vanilla theory and classical logic axioms, it is inconsistent with univalence, so you
may not want to admit it globally in your development. Also, as for any axiom,
it will result in stuck computations: Equations definitions relying on it will only be
simplifiable using simp but no longer compute using e.g. Eval compute.
Consequently, Equations offers both options: you can declare it only for the types
for which you can prove it or need it, or assume it globally:
Assuming you can prove it, from e.g. decidability of equality
Dangerous, incompatible with univalence, and results in stuck computations.
Equations provides tactics to access the pattern-matching and simplification
engines directly inside proofs.
When indexed inductive types are involved, it often provides better simplification
tactics than the default injection and inversion tactics, that can handle
dependent cases.
To explicit pattern-matching and control the naming of variables/hypotheses
introduced by an elimination, it is possible to use the
dependent elimination tactic, which provides access to the Equations
pattern-matching notation inside proofs.
Note that the syntax of the patterns for dependent elimination follows the
syntax of Equation definitions clauses, rather than the Ltac tactics as clauses.
Goal ∀ n m, n + m = m + n.
Proof.
induction n as [|n' IH]; intros m.
dependent elimination m as [O|S m'].
Abort.
As for Equations definitions, the patterns should cover solely the possible
values of the hypothesis.
x : vec nat 2, so the only possible case to consider is two vcons applications
ending with vnil.
H : vcons a ... = vcons b ... which implies a = b. noconf H applies
no-confusion and substitution properties recursively to the type of H to
simplify it, resulting in a substitution of b by a in the goal.
noconf H. reflexivity.
Qed.
(* The dependent elimination _ as _ tactic is robust: it will fail if the
given patterns are non-exhaustive or contains unused clauses *)
Goal ∀ a b (x : vec nat 2), (vcons a x = vcons b x) → a = b.
Proof.
intros a b x H.
Qed.
Proof.
intros a b x H.
two vcons applications ending with vnil.
(* This pattern-matching is non-exhaustive for x: vec A 2*)
Fail dependent elimination x as [vcons hd vnil].
(* This pattern-matching contains an unused clause for x : vec A 2*)
Fail dependent elimination x as [vcons hd (vcons tl vnil)|vcons hd vnil].
Abort.
End Tactics.
Abort.
End Tactics.
Inductive eq (A : Type) (x : A) : A → Prop :=
| eq_refl : eq A x x.
In practice, when the values determined are variables as in eq_sym,
the inaccessibility annotation is optional and we can simply write x
or a wild card _ rather than ?(x).
Equations eq_trans {A} (x y z : A) (p : x = y) (q : y = z) : x = z :=
eq_trans x x x eq_refl eq_refl := eq_refl.
For an example, where the ?(t) notation is needed, consider this inductive
definition of the image.
It has one constructor that for all elements a:A generates an element
in its image by f, Imf f (f a).
Intuitively, it means that there is an object in Imf f x provided
that x is of the form f a for some a.
Pattern-matching on im : Imf f t particularise t to be of the form
f a for some a.
As f is not a constructor, f a is inaccessible and we need to write
as ?(f a) in the pattern matching to prevent Equations to try to
interpret f as a constructor.
As an example, we can write a function returning the a associated
to an object in the image :
Be careful that if you forget to mark inaccessible patterns, then Equations
will try to match on the patterns, creating potentially pointless branches.
It is fine in theory as the definition obtained will be logically equivalent
provided elaboration succeeded, but annoying if you want to extract the code as the definition will be more involved.
For instance, if we define vmap'' by matching on n without marking the
pattern associated to n as inaccessible, we can see at extraction that Equations
matched n and end up with absurd branch to eliminates, yielding a more complicated
definition than the original vmap:
Equations vmap'' {A B} (f : A → B) (n : nat) (v : vec A n) : vec B n :=
vmap'' f 0 vnil := vnil ;
vmap'' f (S n) (vcons a v) := vcons (f a) (vmap'' f n v).
Extraction vmap.
Extraction vmap''.
Using inaccessible patterns hence allows to separate explicitely the subjects of
pattern-matchings and the inferred indices in definitions. The following alternative
definition of the square matrix diagonal pattern-matches only on the vec argument,
but uses well-founded recursion on the index n to justify termination, as
vmap vtail v' is not a subterm of v'.
Equations diag_wf {A n} (v : vec (vec A n) n) : vec A n by wf n :=
diag_wf (n:=?(O)) vnil := vnil ;
diag_wf (n:=?(S _)) (vcons (vcons a v) v') := vcons a (diag_wf (vmap vtail v')).
(* Again, one can observe the extractions of the two diagonal definitions to see
that diag_wf is more efficient, not needing to pattern-match on the indices first. *)
Extraction diag.
Extraction diag_wf.
