Well-founded Recursion using Equations
Summary
Equations is a plugin for that offers a powerful support for writing functions by dependent pattern matching. In this tutorial, we focus on the facilities provided by Equations to define function using well-founded recursion and to reason about them.
In section 1, we explain the interests and the principle of well-founded recursion. We then explain in section 2, how to define functions and how to reason about them using well-founded recursion and Equations. In some cases, applying well-founded recursion can fail because information relevant to termination get lost during recursion. In section 3, we discuss two such cases a how to go around them.
Table of content
  • 1. Introduction to well-founded recursion
    • 1.1 The syntactic guard condition is limited
    • 1.2 Well-founded recursion
    2. Well-founded recursion and Equations
    • 2.1 Using a measure
    • 2.2 Using a lexicographic order
    • 2.3 Using a custom well-founded relation
  • 3. Different tricks to work with well-founded recursion
    • 3.1 The inspect method
    • 3.2 Improving recursion hypotheses
Prerequisites
Needed:
  • We assume basic knowledge of Coq, and of defining functions by recursion
  • We assume basic knowledge of the Equations plugin and of obligations, e.g, as presented in the tutorials Equations: Basics and Equations: Obligations
Not needed:
  • This tutorial discusses well-founded recursion but no prior knowledge about it is required: we will explain the concept
  • To simplify proofs involving arithmetic, we use the automation tactics lia and auto with arith, but they can be used as black boxes
Installation:
  • Equations is available by default in the Coq Platform
  • Otherwise, it is available via opam under the name coq-equations
From Equations Require Import Equations.
From Coq Require Import List Arith Nat Lia.
Import ListNotations.
For Coq to be consistent, all functions must be terminating. To ensure they are, Coq checks that they satisfy a syntactic criterion named the guard condition. Roughly, the guard condition checks that all recursive calls are performed on arguments syntactically detected to be subterms of the original argument. While practical and powerful, this syntactic criterion is by nature limited and not complete: it can happen that functions can be proven terminating using size arguments and mathematical reasoning, even though the guard fails to see them as such.
A common pitfall is when a recursive call is obfuscated, that is when it is not performed directly on a subterm x, but on a subterm to which a function has been applied f x, preventing the syntactic guard from checking that it is still indeed smaller.
For instance, consider the function nubBy below, that filters out the duplicates of a list. The recursive call is not performed on the recursive argument l but on the list filter (fun y negb (eq x y)) l. This is too much for the guard and the function is hence rejected. Yet, we can prove that filter does not increase the size of a list, and hence that the recursive call is indeed performed on a "smaller" instance than l and that nubBy is terminating.
Fail Equations nubBy {A} (eq : A A bool) (l : list A) : list A :=
nubBy eq [][];
nubBy eq (a :: l) ⇒ a :: nubBy eq (filter (fun bnegb (eq a b)) l).
Furthermore, it can also happen that the recursive structure of a definition do not follow the inductive structure of any datatypes, but instead fully rely on semantic arguments to decide which recursive call to perform, logically preventing the guard condition from checking it.
A prime example is Euclide's algorithm computing the gcd of x and y. It performs recursion on x mod y, which is not a subterm of the inputs. Yet, it is terminating, because the sum of the two arguments is a sequence of natural numbers, which strictly decreases and thus cannot go forever. Consequently, there is no hope for a syntactic guard to accept gcd as its definition fully relies on theoretic reason to ensure termination.
Fail Equations gcd (x y : nat) : nat :=
gcd x y with eq_dec y 0 ⇒ {
  | left _x
  | right _gcd y (x mod y)
Informally
It would be limiting if this kind of functions could not be defined. Fortunately, they can be using well-founded recursion.
Informally, defining a function f by well-founded recursion amounts to a usual definition, except that we justify termination by:
  • Providing a "well-founded" relation R : A A Prop, informally a relation for which there is no infinitely decreasing sequence. For instance, the strict order on nat, < : nat : nat nat is well-founded as starting from m : nat, it impossible to decrease infinitely, there is a point at which you must reach 0.
  • Proving that all the recursive calls are performed on smaller arguments according to R
This allows us to justify termination of our function f: since each recursive call is on a smaller argument, an infinite sequence of recursive calls would give an infinitely decreasing sequence according to R, which by assumption cannot exist.
More Formally
In a type theory like Coq's, however, defining a well-founded relation as one "not having infinitely decreasing sequence" is slightly too weak too use properly. Instead, we use the stronger notion of "accessibility" to define well-founded relations R : A A Prop. This is classically equivalent to having no infinite decreasing sequence, but in an inductive definition which is much easier to use.
An element a : A is accessible for R, denoted Acc R a when all a' : A smaller than a, a' are themselves accessible. Intuitively, it constructively ensures that they are no decreasing sequence as the only ways for an element a to be accessible are that:
  • 1. There are no elements smaller than a, so you cannot decrease further
  • 2. All elements smaller than a are accessible, so there are no infinitely decreasing sequence from them, and hence from a.
Print Acc.
We then say a relation is well-founded, when (a : A), Acc R a, that is when all inhabitants of A are accessible. It ensures that wherever we start at, we cannot decrease forever.
Print well_founded.
Given a well-founded relation R : A A Prop, defining a function f by well-founded recursion on a : A consists in defining f assuming that f is defined for all a' smaller than a, that is such that R a' a. When specialized to natural numbers and <, this concept is sometimes known as "strong recursion / induction": when defining f n one assumes that f is defined/proven for all smaller natural numbers n' < n.
In practice
There are several methods to define functions by well-founded recursion using Coq. They all have their pros and cons, but as a general rule defining functions and reasoning using well-founded recursion can be tedious.
For instance, consider the Fix construction of the standard library, which is a direct type theoretic definition of the concept of well-founded recursion:
      Fix : ∀ [A : Type] [R : AAProp], well_founded R
            ∀ P : AType, (∀ x : A, (∀ y : A, R y xP y) → P x) →
            ∀ x : A, P x
We can use it to define gcd as:
Lemma gcd_oblig: (a b: nat) (NE: b 0), lt (a mod b) b.
Proof.
Admitted.
Definition gcd_Fix (x y : nat) : nat :=
  Fix lt_wf (fun _nat nat)
      (fun (b: nat) (gcd_Fix: b', b' < b nat nat) (a: nat) ⇒
          match eq_dec b 0 with
          | left EQa
          | right NEgcd_Fix (a mod b) (gcd_oblig a b NE) b
          end)
      y x.
However, doing so has several disadvantages:
The function is much less readable than a usual definition by Fixpoint as:
  • there is an explicit fixpoint combinator Fix in the definition
  • we are forced to use curryfication and change the order of arguments
  • explicit proofs now appears directly in the definition of the function (though Program can help for that)
It also makes it harder to reason about the function as it forces to use recursion on the accessibility proof, which no longer corresponds to the way we think about our function. Moreover, as we had to use curryfication in our definition, we may need the axiom of function extensionally to reason about gcd_Fix.
To go around these different issues, Equations provides a built-in mechanism to help us write functions and reason by well-founded recursion.
To define a function by well-founded recursion with Equations, one must add after the type of the function by wf x R, where x is the decreasing term, and R the well-founded relation for which x decreases, and then define the function **as usual**.
For instance, the function nubBy terminates as the size of the list decrease in each recursive call according to the usual strict order < on nat, lt in Coq. We hence need to write wf (size l) l to define it by well-founded recursion:
    Equations nubBy {A} (eq : AAbool) (l : list A) : list A by wf (length l) lt :=
    nubBy ... := usual_def;
    nubBy ... := usual_def.
Equations will then automatically:
  • 1. Search for a proof that R is well-founded, using type classes (a database) specific to Equations suitably named WellFounded
  • 2. Create an obligation to prove that each recursive call is performed on decreasing arguments, try to prove it automatically, and if it cannot do it on its own leave it for us to prove
This allows to write our definition transparently and directly as we would like to. In particular, we do not need to alter the structure of the definition to get it accepted, and it allows us to separate the proofs that the recursive call are smaller from the definition, making it easier to read and define while automatically dealing with trivial cases.
In the following, we assume basic knowledge of obligations and Equations works together as discussed in the (short) tutorial Equations: Obligations.
2.1 Using a measure
The most basic (and actually very versatile) method to define a function by well-founded recursion is to define a measure into nat to use the well-founded order <, that is a function m : ... nat depending on the arguments, and to prove the measure decreases in each recursive call.
A simple example is the size of an inductive value, i.e. the maximal number of nested constructors. Is already enough to define the function nubBy, that recursively filters out the duplicates of a list, by well-founded recursion. Indeed, the size of a list is its length, and the only recursive call performed by nubBy is on filter (fun y negb (eq x y)) l. As filter can only remove elements, its length is indeed smaller than l's, and the function is terminating.
To define nubBy using Equations and well-founded recursion, it suffices to add wf (length l) lt after typing to indicate on which term, here length l, and for which well-founded relation, here lt (the relation behind the notation <), we wish to use well-founded recursion. An obligation corresponding to proving that the recursive call is smaller, that is length (filter (fun y negb (eq x y)) l) < length (a :: l), is created. As Equations cannot solve on its own, it then left to us to solve. Using the keyword Equations?, it is automatically unshelved, and we simply have to prove it using tactics.
Equations? nubBy {A} (eq : A A bool) (l : list A) : list A by wf (length l) lt :=
nubBy eq [][];
Proof.
  eapply Nat.le_lt_trans.
  - apply filter_length_le.
  - auto with arith.
Qed.
Reasoning on functions defined with well-founded recursion with Equations, is no different than on regular functions. Using function elimination (funelim) we can prove our properties directly according to the pattern of our definition. In particular, we do not have to do proofs by well-founded induction. This completely hides well-founded recursion and allows us to reason about our function directly as we think about it.
This is a very powerful method that, for instance, enables us to prove in a few lines that nubBy does remove all duplicates.
Lemma In_nubBy {A} (eq : A A bool) (l : list A) (a : A)
               : In a (nubBy eq l) In a l.
Proof.
  funelim (nubBy eq l); simp nubBy; cbn.
  intros [Heq | H0].
  - rewrite Heq. left; reflexivity.
  - specialize (H _ H0). apply filter_In in H as [Inal eqa].
    right; assumption.
Qed.
Lemma nubBy_nodup {A} (eq : A A bool) (l : list A) :
      ( x y, (eq x y = true) (x = y)) NoDup (nubBy eq l).
Proof.
  intros Heq; funelim (nubBy eq l).
  - simp nubBy. constructor.
  - specialize (H Heq). simp nubBy. constructor.
    -- intros Hi.
       apply In_nubBy in Hi.
       apply filter_In in Hi as [Hl Hneqx].
       specialize (Heq a a); destruct Heq as [_ Heqx].
       specialize (Heqx eq_refl); rewrite Heqx in Hneqx.
       inversion Hneqx.
    -- assumption.
Qed.
For a slighlty more involved consider a gcd function that does not require the assumption that x > y, by first checking if x or y is 0, and otherwise compares x and y, and recalls gcd with x - y or y - x depending on which is greater. We cannot prove it is terminating either by looking if x or y decreases (the size of a number is the number itself) as we do not know upfront which of x or y is bigger. However, we can use that the measure x + y is decreasing for the usual well-founded order on nat, as if x and y are strictly greater than 0, then x + y > x + (y - x) = y and x + y > y + (x - y) = y.
We can define gcd by well-founded recursion by annotating the definition with wf (x + y) lt. We then get two obligations corresponding to the recursive goals, which are basic arithmetic goals and can be solved using lia.
Equations? gcd (x y : nat) : nat by wf (x + y) lt :=
gcd 0 x := x ;
gcd x 0 := x ;
gcd x y with gt_eq_gt_dec x y := {
| inleft (left _) := gcd x (y - x) ;
| inleft (right refl) := x ;
| inright _ := gcd (x - y) y }.
Proof.
  all: lia.
Defined.
For further examples of how functional elimination works on well-founded recursion and how useful it is on complex definitions, we will now show a few properties of gcd.
Lemma gcd_same x : gcd x x = x.
Proof.
  funelim (gcd x x). all: try lia.
Qed.
Lemma gcd_spec0 a : gcd a 0 = a.
Proof.
  funelim (gcd a 0). all: reflexivity.
Qed.
Lemma mod_minus a b : b 0 b < a (a - b) mod b = a mod b.
Proof.
Admitted.
Lemma gcd_spec1 a b: 0 b gcd a b = gcd (a mod b) b.
Proof.
  funelim (gcd a b); intros.
  - now rewrite Nat.Div0.mod_0_l.
  - reflexivity.
  - now rewrite (Nat.mod_small (S n) (S n0)).
  - now rewrite refl, Nat.Div0.mod_same.
  - rewrite H; auto. now rewrite mod_minus.
Qed.
Not all definitions can be proven terminating using a measure and the strict order < on nat. In some cases, it is more practical to use a different well-founded order. In particular, when a function involves recursion on different arguments but not all recursive arguments are smaller at once, it can be practical to use a lexicographic order <lex. Given two order <A : A A Prop and <B : B B Prop, (a,b) <lex (a',b') iff a <A a' or a = a' and b <B b'. This is useful, as it suffices for one argument to decrease for the recursive call to be smaller. Moreover, <lex is well-founded as soon as <A and <B are.
A classical example where it is useful, is to define the Ackerman function:
Fail Equations ack (m n : nat) : nat :=
ack 0 n := S n;
ack (S m) 0 := ack m 1;
ack (S m) (S n) := ack m (ack (S m) n).
Indeed, it is terminating as the recursive call are all smaller for the lexicographic order, which is essential to deal with the last case:
  • (m,0) <lex (S m, 0) as m < S m
  • (m, ack (S m) n) <lex (S m, S n) as m < S m
  • (S m, n) <lex (S m, S n) as S m = S m and n < S n
To define ack by well-founded recursion, it suffices to add (lexprod _ _ lt lt). The function lexprod builds the lexicographic order and derive a proof that it is well-founded provided that both order are. As we can see, with this order, the obligations generated turn out to be simple enough to be automatically dealt with by Equations.
Equations ack (m n : nat) : nat by wf (m, n) (lexprod _ _ lt lt) :=
ack 0 n := S n;
Reasoning about ack works as usual whether the pattern is general or specialized:
Definition ack_min {m n} : n < ack m n.
Proof.
  funelim (ack m n). all: eauto with arith.
Qed.
Definition ack1 {n} : ack 1 n = 2 + n.
Proof.
  funelim (ack 1 n); simp ack.
  - reflexivity.
  - rewrite H. reflexivity.
Qed.
In some cases, there is no basic order that easily lets one define a function by well-founded recursion. In this case, it can be interesting to:
  • 1. Define your own relation R : A A Prop
  • 2. Prove it is well-founded wf_R : well_founded R
  • 3. Declare it as an instance so that Equations can find it with Instance name : WellFounded R := wf_R.
For instance, suppose we have an infinite sequence f : nat bool of booleans, such that we know logically that there is at least one that is true h : n : nat, f n = true. This is represented by this context:
Section LinearSearch.
Context (f : nat bool).
Context (h : m : nat, f m = true).
Knowing there exists an m : nat such that f m = true, we would like to actually compute one. Intuitively, we should be able to just try them one by one starting from 0 until we find one, and it should terminate as we know there exists a m such that f m = true. However, it is not clear which classical measure or relation to use to formalise this intuition. We will hence use a custom relation R n m.
We want to distinguish whether n < m or m n:
  • When m n, we do not care about Acc n as we are supposed to have already found m. As we know that f m = true, to discard these cases automatically, we add k, k m f k = false to the relation to get f m = false.
  • By the previous point, we know that Acc m. Consequently, to prove Acc n when n < m, we want to reason by induction on k := m - n. To do so, we add n = S m to the relation.
This gives us the following relation and proof of our intuition. Note that understanding the proofs doe not matter for this tutorial.
Definition R n m := ( k, k m f k = false) n = S m.
Lemma wf_R_m_le m (p : f m = true) : n, m n Acc R n.
Proof.
  intros n H. constructor. intros ? [h' ?].
  specialize (h' m H).
  congruence.
Qed.
Lemma wf_R_lt_m m (p : f m = true) : n, n < m Acc R n.
Proof.
  intros n H.
  (* Prove Acc m *)
  assert (Acc R m) as Hm_acc by (eapply wf_R_m_le; eauto).
  (* Set up induction on k := m - n *)
  rewrite <- (Nat.sub_add n m) in × by lia.
  set (k := m - n) in *; clearbody k. clear p H.
  (* Proof *)
  induction k.
  - easy.
  - apply IHk. constructor. intros ? [? ->]. assumption.
Qed.
We can now prove that the relation is well-founded:
Lemma wf_R : ( n : nat, f n = true) well_founded R.
Proof.
    intros [m p] n. destruct (le_lt_dec m n).
    - eapply wf_R_m_le; eassumption.
    - eapply wf_R_lt_m; eassumption.
Qed.
Having proven it is well-founded, we declare it as an instance of the database WellFounded so that Equations can find it automatically when using the keyword wf x R.
Instance wfR : WellFounded R := wf_R h.
We are now ready to define our function by well-founded recursion.
Here, for technical reason we use the inspect method to remember the value of f m. Here, it is not necessary to understand it for our purpose, and we refer to section 2.1 for more details on the method.
Definition inspect {A} (a : A) : {b | a = b} := exist _ a eq_refl.
Notation "x 'eqn:' p" := (exist _ x p) (only parsing, at level 20).
Even though we want to start a computation at 0, to define our function by well-founded recursion we need to start at a generic point m : nat, to actually have a term to do our recursion on:
Equations? exists_nat (m : nat) (H : n, n < m f n = false) :
  {n : nat | f n = true} by wf m R :=
exists_nat m H with inspect (f m) :={
  | true eqn:p ⇒ (exist _ m p)
  | false eqn:pexists_nat (S m) _
Proof.
- inversion H0; auto.
- unfold R. split. 2: reflexivity.
  intros k ikm. inversion ikm. 1: assumption.
  subst. apply H. auto with arith.
Qed.
Theorem linear_search : {n : nat | f n = true}.
Proof.
  unshelve eapply (exists_nat 0).
  intros n Hn0; inversion Hn0.
Qed.
End LinearSearch.
3. Different methods to work with well-founded recursion
When defining a function, it can happen that we lose information relevant to termination when matching a value, and that we then get stuck trying to prove termination.
In this section, we discuss two such example an methods to go around the issue. Note that the inspect method was already used in section 2.4.
Working with a particular well-founded order lt, it may happen that we have a choice function f : A option A that for any (a :A) returns None or a strictly smaller element. This situation is axiomatised by the following context :
Section Inspect.
Context {A : Type} {lt : A A Prop} `{WellFounded A lt}.
Context (f : A option A) (decr_f : n p, f n = Some p lt p n).
In this case, given an element (a : A), we may be interested in computing the decreasing chain starting from a specified by f. Naively, we would like to do it as follows: first, we check if there is an element smaller than a by matching f a with a with clause; if there is none, then we stop the computation, otherwise we get Some p and we returns p added to the chain starting with p, i.e., our recursive call f_sequence p.
Equations? f_sequence (a : A) : list A by wf a lt :=
f_sequence a with (f a) := {
  | Some pp :: f_sequence p;
  | Nonenil
Proof.
  apply decr_f.
  (* What to do now ? *)
Abort.
Unfortunately, as we can see, by doing so we generate an unprovable obligation as we do not remember information about the call to f n being equal to Some p in the recursive call f_sequence p.
To go around this issue and remember the origin of the pattern, we can wrap our match with the inspect function, which simply packs a value with a proof of an equality to itself. In other words, given an element (a : A), inspect (a) returns the elements (a, eq_refl) : {b : A | a = b}.
Print inspect.
In our case, wrapping with inspect means matching first on inspect (f a) then on the first component which is by definition f a, rather than directly on the term f a. This may seem pointless as if one destruct f a in an equality f a = f a, one would surely get Some p = Some p and learn nothing? The trick here is that inspect (f a) returns an object of type {b : A | f a = b}, type in which f a is a fixed constant. Consequently, destructing the first component, in our case f a, will only affect the right-hand side of the equality, and we will indeed get the desired equality f a = Some p. As it can be seen below it works perfectly, and Coq is even able to prove the call is terminating on its own leaving us no obligations to fill.
#[tactic="idtac"] Equations? f_sequence (a : A) : list A by wf a lt :=
  f_sequence a with inspect (f a) := {
    | Some p eqn: eq1p :: f_sequence p;
    | None eqn:_List.nil
Proof.
  apply decr_f. assumption.
Qed.
End Inspect.
In some cases, most particularly when using a size or measure, it can happen that when defining a function by well-founded recursion, we forget that x is a subterm of a larger term Y, and then we get stuck proving that "size x < size Y". In this case, a possible solution is to define a custom function to "carry" the information that x is a subterm of Y, so it is available when trying to prove it is well-founded.
For an example, consider RoseTrees, trees with finite subtrees represented by the constructor node : list RoseTree RoseTree. Let's also define the usual size function on it, and an equality test on lists.
Section EqIn.
Context {A : Type}.
Inductive RoseTree : Type :=
| leaf : A RoseTree
Equations sizeRT (t : RoseTree) : nat :=
sizeRT (leaf a) := 1;
sizeRT (node l) := 1 + list_sum (map sizeRT l).
Equations eqList {X} (l l' : list X) (eq : X X bool) : bool :=
eqList [] [] _ := true;
eqList (a::l) (a'::l') eq := andb (eq a a') (eqList l l' eq);
eqList _ _ _ := false.
For pedagogical purposes, having define an equality test on list, we would like to define an equality test on RoseTree using well-founded recursion.
If we try to define the equality test naively as below, Equations generates the obligation sizeRT l < 1 + list_sum (map sizeRT lt) corresponding to the case where lt := l :: _. This is obviously true, but we are stuck trying to prove it as we do not remember that l is in lt:
Equations? eqRT (eq : A A bool) (t t': RoseTree) : bool by wf (sizeRT t) lt :=
eqRT eq (leaf a) (leaf a') := eq a a';
eqRT eq (node lt) (node lt') := eqList lt lt' (fun l l'eqRT eq l l') ;
eqRT eq _ _ := false.
Proof.
    simp sizeRT.
    (* What to do know ? We have forgotten that x is in l,
      and hence that sizeRT l < 1 + list_sum (map sizeRT lt)  *)
Abort.
To go around this kind of issues, a general method is to strengthen the function that goes through the structure to remember that x in a subterm of Y. In our case, it means strengthening eqList so that to remember that l is in lt. To do so, we ask for the input of the equality test eq of eqList to additionally be in in l, i.e. eq : x : X, In x l X bool. This way, in the case (lt := l :: _) we remember In l lt. Doing so, it is now possible to define eqRT by well-founded on the size:
Equations eqList' {X} (l l' : list X) (eq : x : X, In x l X bool) : bool :=
eqList' [] [] _ := true;
eqList' (a::l) (a'::l') eq := andb (eq a _ a') (eqList' l l' (fun x Inl yeq x _ y));
eqList' _ _ _ := false.
Definition list_sum_ine (x : nat) (l : list nat) : In x l x < 1 + list_sum l.
Admitted.
eqRT eq (node lt) (node lt') := eqList' lt lt' (fun l Inl l'eqRT eq l l') ;
Proof.
  simp sizeRT. apply list_sum_ine. apply in_map. assumption.
Qed.
End EqIn.
